Ranger build
    salem eh?? im right down the street from you.
    im so glad im seeing something other then then a xj.........rippin
      Sweet build, but at what point do you say 'why even bother having doors'?
      I have full doors for the winter, I only have one half door for the driverside (free door dont have a passenger side one yet). its mainly to be legal on the road. The door bars on my cage are going to be in the way anyways, the doors are more just a skin to either keep cold out or keep me legal. Its going to be a dukes of hazzard style entry and exit.
      Bent Fab Evo4 Rockwell Buggy
      2011 Silverado 6.2L LT
      2009 Pontiac G8 GT
      2004 Z1000
      1999 TJ
        sweet build
          Its just taken way to long at this point. When I started it, I really didnt know what I was doing. Didnt even know how to weld at that point. but I will say its helped me learn loads of stuff about wheeling and fabrication.
          2009 Pontiac G8 GT
          2004 Z1000
          1999 TJ
            Looks good! Cool rig! Nice to see something different!
            HOONIGAN FOR LIFE
            OLD 4X4'S NEVER DIE!!!!!
              Little bit of boxing on the frame for mounting purposes.
              I also just bought a set of sweet motor mounts.
              2009 Pontiac G8 GT
              2004 Z1000
              1999 TJ
                Solid Body mounts almost all cut out. My bandsaw blade finally let go just as it finished one. So I need to pick up another blade to cut the last two. I built in a 1/2" "body lift" into the pucks so it gives me a little bit more clearance around the trans/tcase.
                2009 Pontiac G8 GT
                2004 Z1000
                1999 TJ
                  Should have continued to box the rest.
                    With the cage going in it wont be needed. The frame is going to be pretty stiff.
                    2009 Pontiac G8 GT
                    2004 Z1000
                    1999 TJ
                      This is one sick ranger, sweet build.
                      -Matt
                      Facebook
                        I would have boxed the entire frame! Body lift? Why? Body lifts imo suck!!!! Good looking rig though!
                        HOONIGAN FOR LIFE
                          in my travels i came across a 76 ford dana44 hp housing with knuckles, i think it was on kissmydiff.com no positive tho, just made me think of you...
                            Its only half an inch and its built into the body mounts. Since these are replacing the stock rubber mounts its all one peice, the short pucks that say .75" are for under the frame mount. they are a "washer" the frame mounts have like a 1.25" hole in them so I couldnt just use a regular washer so I made these instead. I have to pick up some 1/2" grade 8 bolts for these.
                            2009 Pontiac G8 GT
                            2004 Z1000
                            1999 TJ
                              I like seein this, ive never seen a ranger build before
                                4xdigital labs built a real nice... ahhh nevermind
