Not even sure if this would be considered mild. Needed a dd as my other jeep went down and this thing was resurrected.
Here's the specs;
- 2001 XJ Sport
- 99,985 Miles On The Clock
- HP D30
- C8.25
- AW4
- NP231
I picked it up for $500 as it needed some work. Guy basically just wanted the thing out of his driveway, and him not being too car savvy thought something serious was wrong with it.
Now onto some tech.
The night i went to pick it up i started it up, pushed the brake pedal and PSSSSH! Brake lines failed instantly. Replaced all of those. Made this home-made brake bender tool that can put super tight radius bends in brake line without kinking it.
Alternator and A/C were totally seized. I replaced the alternator ($80), and then swapped one of my spare A/C compressors into it. Serpentine belt was also snapped so i put a new belt in it. Also bought a new battery.
Started it up and encountered the problem the previous owner was experiencing. "It overheats the mechanic said the headgaskets blown". That's exactly what he told me. I'm leaning towards a cracked head if anything but i wasn't going to start telling him this.
Anyways, i replaced the entire cooling system. Total overhaul. Everything minus the heater core has been replaced. Cost me right around $200. Let the jeep idle for an hour or so and the thing idles perfect and the temperature stay right under 210 (100c).
It's not eating coolant either so that's a plus. Oil pressure is high too! Win Win! If i do have to do a head, so beat it, it's $450 shipped to my door.
Another problem is the rear brakes. The drums were totally locked up. Had to pull the jeep onto the trailer with a 3-ton come-along and the rear brakes just dragged the entire time.
Currently putting disc brakes on the rear of the jeep to get the brakes in working order. Also noticed the fuel line was rusted out (surprised it hasn't gone through.)
Bought a 25' roll of 5/16" fuel line for $18.
Another thing i noticed is that everything under the jeep is rusty. (Except the unibody and body. I don't understand.)
The axles, driveshafts, exhaust, leaf springs, etc are totally rusted. I think i'm going to swap the axles from my other jeep into this one and make them look all nice before i swap them in.
I just don't know if a HP D30 will fit into an 01. I think the pinion will hit on the exhaust because of the precats or something like that. I think you need 3" of lift to clear. I can't remember.
Here's the specs;
- 2001 XJ Sport
- HP D30
- C8.25
- AW4
- NP231
Now onto some tech.
