Project oddie
  • #46
    any progress?
    95 xj JY 3" 35" truxus mt's
    • #47
      I gotta get a fuel pump fior her, I sprayed some starting fluid in it and it ran so that was a plus. bought a 31 spline 9 inch carrier, got to order a mini spool from Dan
      • #48
        Are you going to run an e2000? What gears are in the 9"?
        • #49
          Well I got her running today! I bought a Jazz fuel cell from Sardo, and used 3 walboro fuel pick ups inside the tank and a holley external fuel pump. Hooked everything up, and the fuel pressure was a bit low so I bumped it up to the recommend level(12.5-15psi) and it runs pretty damn good. I did pull a stupid and left some switches on and killed my Optima .
          Today I got her moving and went to Matt Dinicolas and picked up a set of front EB axleshafts. so the project is moving along, there are quite a few hack job things like fuel lines run under the header, so Im going to clean up those things and run some brake lines to the rear and get shit done.
          • #50
            at lest we fixed some of the wireing
            97' zj
            2012 surbra imperza DD
            • #51
              Raced it yet?
              • #52
                Prolly not going to happen due to it being my rig
                • #53
                  Make this thing do something!!!!!!!!!!!!!!!!!!!!!!!!!
                  97 XJ.
                  • #54
                    you know you wanna bounce it of the rev limiter...
                    00 xj hp44 aussie lsd 5.38s, d60 welded 5.38s, 37" MTR Kevlars on 17" H2 wheels, chevy one ton steering, comanche rear leafs, 11" inch travel bilsteins in the front 14" in the rear
                    98 xj hp30 open 4.10s, 8.8 lsd 4.10s, 33" duratracs on 16" moabs, ruffstuff frame stiffeners, custom 3 link 3/4 heims for the upper and 1.25 for the lowers, f150 10" travel shocks in the front with 3" coils and yj brake hoses, an extra main leaf in the rear and 1.5" lift shackles in the rear
                    • #55
                      Not a crazy big update, but I have 31 spline yukon shafts, a 31 spline full spool al coming in for the 9 inch. Also starting to go through the electrical nightmare. The way things are wired in this truck are crazy, I am goign to try and pull any wire I dont need out just to clean it up a bit. Ill prolly be ordering a outer shaft for my d44 in the next week or so, so I can get the other alloy shaft in.
                      So in my opinion I like the progress it does suck that I couldnt work on it much this winter do to the cold and the snow but shit is coming together. Hopefully and mabell run for this pig come the end of april.
                      • #56
                        Can't wait for you to roll it!!
                        Dizz dizz go sleep sleep
                        Driver 4677 FSM vehicle
                        • #57
                          youll have to wait 3 years until he decides its not worth it anymore and rolls it onto a trailer for the scrapyard
                          Originally posted by DizzDizz View Post
                          So me and Caleb acquired a 1991 ranger from his cousin. We're gonna race it at line mountain hopefully on July 20th if not most def September race. ( let the betting begin).
                          let the record show im not far from the truth
                          1945 Willys-Overland CJ2A
                          • #58
                            HOONIGAN FOR LIFE
                            OLD 4X4'S NEVER DIE!!!!!
                            • #59
                              Rear axle shats in, spool in, rear , disks done, its on all 4, i drove it yesterday then the fuel pump died . Almost ready to roll
                              • #60
                                Hahaha you said shat
