Zips 2.0 My 98
  • Seriously? Have you seen my jeep?
    • Dan's is concourse-ready compared to Phil's.
      Suck it up, you did some unibody damage. Reinforce your shit.
      • Originally posted by Robin Fairchild View Post
        I don't think you've seen my jeep lately! Anyway, that is nothing. At least no reason to sell it.
        • Not close to selling any more. I'm going to stiffen it 2x6 and trim the doors. I can't sell it after that shit and the fact of it managed to survive me beating it all weekend. question with out out boarding how can I get my shocks up higher? I am not liking no rear shocks.
          General Tires are
          • Cut the lower brackets off. Center the lower mount on the axle tube. Burn away.
            • http://stores.dmrtransmission.com/-s...Categories.bok
                Ok but that doesn't help the fact I didn't have a shit ton of up travel if I move them up any more I will barely have any up travel at all.
                General Tires are
                • Originally posted by Luke95 View Post
                  Ohhhhh boyy
                  You do realize you raise the lower mount? Or else that modification would be pointless
                  -54 Dodge Power wagon M-37
                  -57 GMC Pickup
                  -Tim (OIIIIIO)
                  • Originally posted by CntStpTheStnk06 View Post
                    Ohhhhh boyy
                    Thats what hes saying. If he only raises the lower mount there will be no up travel. So you either need shorter shocks, or hoops like I posted.
                      Ohhhhh boyy
                      I get this I may just throw in some stock shocks with them raised for now then do the hoops when I have money again.
                      I will loose some down travel oh well.....
                      General Tires are
                      • I have been running stock length shocks in the rear with the mounts raised for like 3 years. It's not an RTI champ, but it's fine. If I felt it hindered performance a lot, I'd have changed it. Proper bumpstops are crucial.
                        That being said, I will definitely be going through the floor with the shocks once my cage is done.
                        97 XJ.
                        • My shock mounts cut off shortened and reused seams to work good best part there free.
                          • Originally posted by Harry View Post
                            Im not seeing an issue. I cant see a problem with it until I have a major remodel. I want to go bilstien and through the floor out back but till then cheap is good.
                            General Tires are
                            • I just said fuck it.
                              Welded em back on then put in a peice of square 120 wall tube as an upper mount.
                              Today I am going to look at the DD mod.
                              F2shity IDI Supercab with a 7.tree
                              General Tires are
                              • That truck sucked dick. But.....
                                The Powerchoke is becoming a reality! DD status!
                                No more dd for my heep! Time for stiffeners new shafts up front rear floor is getting cut! Going to cut my rear fenders to fit some bigger meats. Some new meats are in the plans. A new setup for steering is also being thought up. I am pumped for this! No more worrying about making it to work in the morning!
                                Loving my job even more just got my apprenticeship all filled out and filed. Life's looking up finally.
                                General Tires are
