Does anyone want a set of xj 44 shafts as spares? The splines are twisted, but theyhave decent bearings and brand new lug studs. Uhhh how's 2 12 packs of summer shandy sound or something else just as tasty.
xj d44 rear shafts
I have a housing $100. mounts ground off.
$40 for disk brake calipers,pads and brackets.
$60 for brand new carrier and used 4.11 gears and bearings.RCrocs #123 Brown CJ-5
these brakes and brackets.. got anymore info you can give meh? i want dis.Originally posted by customcreationsllc View PostI have a housing $100. mounts ground off.
$60 for brand new carrier and used 4.11 gears and bearings.98 xj, 4.0, AW4, 231 AA SYE, 4.5"RE/RC, CA drop brackets, 33s, and some other stuff
GM metric calipers and weld on brackets.Originally posted by Dirtyjeep92 View Postthese brakes and brackets.. got anymore info you can give meh? i want dis.
you just need to use front rotors in the rear and line every thing up then weld.
A little grinding of the caliper bracket is needed.
