Someone just called the shop and this was the Convo.
"Gunsmithing, This is Phil."
"Mitch?"
"No this is Phil, Mitch isn't here today, how can I help you?"
"Mitch isn't there? That's not good. Who am I suppose to yell at?"
"Well, you can call back tuesday and Yell all you want."
"Sounds good. Bye."
click.
sigpic Official Space Shuttle Door Gunner of the Chechnyan Space Program
if someone can look at your rig and still tell what it was, then you have a long way to go before its destroyed. if you continue to wheel it after said destruction then you are truely special. :shock:
Someone just called the sho and this was the Convo.
"Mitch?"
"Sounds good. Bye."
I also just got done trying to explain to a customer how his Mauser Red 9 works and it completely baffled him so he left it here 'to let us figure it out'.
no woke up late and worked on the dodge will do in a little while. Also for how fucking fugly that thing is it is a blast to shoot. How far out was it?
It wasn't terrible, just 3 grids off on the boresighter.
Next time you shoot it, we can adjust the sights futher.
Some dude just came into the shop and didn't know the difference between a Red Dot Laser, a Red Dot sight and Iron sights.
It was so extremely confusing to figure out what the fuck he wanted.
"I want you to cut the barrel down and install laser sight"
Do you want to install a rail on the bottom of the barrel?
"No, I want it up here at the end of the barrel"
So you want a new front iron sight.
"Yeah, a laser sight."
Wait. You need to explain to me what you want.
"I want a laser sight like this one."
That's an Iron sight...problem is we can drill and tap your barrel but we'll need a one inch spacer so the sight line up.
"So you can't just cut the barrel and install a new sight?"
No, you need a Form 1 from the ATF to cut the barrel down to anything less than 16"
"Really?"
Yes.
"I guess it isn't worth it then.. Oh well, thanks anyway."
It's going to be a long day...
