I loved them once i got the coilovers set up right and the camber dialed in.
I've opted to go with some sticky rubber for the spring, rt615s,re01rs, or the star specs most likely, track density motor mounts, a rear sway bar, a high pressure fuel pump, water/methanol injection, a front mount intercooler, and then bump up to stage 2+ and in conjunction with the water/meth be able to run a 100 octane file. I should put down 300ish hp and 330ish ft. lbs of tq., trap somewhere around 108-110mph with a 12.9-13.0 quarter time bc wheel spin sucks.
