Leaf springs win
    Originally posted by Cletus View Post
    cool kids are doing coil over airshocks
    ballistic's hybrid shocks
      i recently found a build on pirate that was portal axles with a cantilevered system all around thad has air/nitro suspension inside the frame rails. it was bad ass
        1/4 eliptical is so sick
          may know someone who is getting them for christmas
            Originally posted by JoeNitro View Post
            i like all leafs better than all coils. i hate how my girlfriends tj is. i hate track bars and sway bars and with all coils you need both. xj for the win.
            nope, nope and nope
            i dont have a track bar in the rear (4-link). and my offroad sway bar rules. and last time i checked your xj has a trackbar and swaybars too
              Originally posted by grundlepunch View Post
              nope, nope and nope
              it has one track bar. which is less than 2 that the tj has. and no my xj does not have swaybars. the tj does because i dont know anyone who would run a full coil vehical without atleast one.
              #becauseJoeNitro
                Evan has no sway bars and a full coil rig
                    shits tighter than an asian nun
                      humm must be the rough country stuff then cuz without the front sway connected on the tj its way to sketchy to drive at speed. are they known for haveing soft springs or something?
                      #becauseJoeNitro
                        if anything the rough country springs should have a heavier spring rate. someone prove me wrong cause I really dont know. But most aftermarket companies build them heavier to be able to support heavier bumpers and make them more able to withstand harder off road use.
                          maybe its the short wheel base then? when you take a turn at speed with the sway off on the tj the body roll is scary and it over steers like its its job.
                          #becauseJoeNitro
                            I dont have a problem with mine maybe im just used to driving my cherokee which is far worse than my TJ. TJ has the rear sway bar, XJ has none. and im not the only one here who has no sway bars in their XJ
                              my xj also has none. and its a cadilac comapred to the tj. idk thats weird...
                              #becauseJoeNitro
                                wtf are you doin in a TJ to experience severe oversteer?
