tech opinion pt.II
  • tech opinion pt.II
    the bushings on the shift forks inside the np242 had come loose and got fucked up when I spit a ujoint in wyoming.. causing my catastrophic failure into Sturgis, SD. I got everything off the jeep today and on inspection, I see that the gear selection "couplings" have maimed the shift forks, making them unusable.. what this all boils down to is this.. my options are
    continue to search for a proper np242 and try to make a trade so the price is reasonable....
    OR....
    Weld the couplings into their proper places on the shaft, leaving the selection of 4wd options at only 4hi, full time, with the front driveshaft pulled..
    what, in the eye's of SIS, would be more REAL!?
    (it's a no brainer as to "real" but it is somewhat not smart.......)
    weld the fucker. whats the worst that could happen?
      btw, if rj shipped you a 242, you cant swap the shift fork and mix and match?
        oh, and you suck at making polls
          just swap in a 231..
            your staying with a friend right now right? if so wait for the parts n fix it right.
            you do it the other way and something will break and then your stuck in the middle of nowhere, knowing nobody. will likely cost you more in the long run just to get home earlier.
              rent a truck and a trailer.
              Fight Team
              Official HMC Girlie
