How many cubic inches is a 4.0l?
  • How many cubic inches is a 4.0l?
    just wondering
    242 ci. 3960 cc
      wrong
      4 liters= 244.094 ci
        http://www.google.com/search?q=4+lit...ient=firefox-a
            Specifications (2003)
            Description: in-line six, overhead valve (two per cylinder), flat-face followers, hydraulic lifters, cast iron block and head
            Displacement: 3960 cc (242 cubic inches)
            Bore and stroke 98.4 mm x 86.7 mm
            Compression ratio 8.8:1
            Redline: 5,300 rpm
            Maximum power, 2003, Wrangler:
            * USA - 190 hp (142kW)@4,600 rpm; 235 lb-ft (319 Nm) @ 3,200 rpm
              i said 4 liters i didnt specify a certain engine
                touche costmart
                  wrong
                  242 in³ = 3.96566 L
                  they rounded up
                    Originally posted by ruecifur View Post
                    242 in³ = 3.96566 L
                    they rounded up
                    bame.
                      all people round up. the ford 5.0 mustang engine is really a 4949cc, so it is closer to a 4.9 litre.
                        wrong
                        if you knew the answer what was the point of the tread
                          if i told you, you couldn't compehend it.
                          it has to do with myself and the void
