Removing a TCase the easy way.
  • Removing a TCase the easy way.
    Currently sitting on the side of the highway waiting for a tow.
    Rear end locks up followed by my TCase and driveshaft ripping out of the jeep.
    Had to run down the highway and pick up my TCase and driveshaft. It's a mess.
    Story over.
    Hudson
    holy CRAP. that looks like it was violent...
      I came into this thread with the homes of telling you the easiest way to get a Tcase out is a grenade above the Tcase, but it seemed like you had one inside the tcase!
      Holy fucking shit, that must have been quite the noise!
        Hudson
          Daaaayyyyyuuuuummmmmm
              Did that on 84, except my front ds seized which was the cause.
                I grenaded mine going down the highway a few weeks ago, the entire side going to the front end split , chain held everything together enough to limp to town
                  Holy Chanukah
                    pro comp?
                      well that would make a hellacious noise. Whyd you go and do that?
                        Procomps will get you EVERYTIME!
                        Dizz dizz go sleep sleep
                        Driver 4677 FSM vehicle
                          Yeah, was doing 80MPH at the time it happened. I noticed the vibrations were getting worse, then it starting making a clunking so i started merging to the side of the highway to pull over when it just exploded.
                          It was the first time i ever saw a T-case bouncing down the highway in my rear view mirror.
                          Anyways i have a few questions/concerns.
                          I was doing 80 MPH when this happened. Around ~3,000 RPMs. I'm pretty sure the torque convertor was locked. When the T-case ripped out the jeep turned off immediately.
                          I think the CPS realized something went wrong and just killed the engine. I figure the only damage that was done was to; T-Case, Driveshaft, SYE, rear axle.
                          I don't think the transmission or engine is messed up but i don't know for sure. I do know for fact that the Centering ball on the rear driveshaft was toasted, but i don't think it could cause all of this to happen. I think something froze up (the T-case or rear end) then the driveshaft transferred the torque from going 80MPH through the driveline and the first thing to give was the T-case. It literally looks like it just twisted off.
                          Where would you guys go from here?
                          Hudson
                            I would cut a hole in the floor(if the rust hasnt gotten it yet) and flintstone it around
                              that shit cray
