that should work...and dickerman...those wheels work mint but itll work better with PVC...im so happy its almost 100%
Trike Drifting
Introducing the nutt burner 5000 it burns your nuts as fast as you can pedal, aslo gets rid of that hard to reach taint hairOriginally posted by Calabrate2 View Post
97' zj
2012 surbra imperza DD
i spent a long time in tractor supply last night looking for wheels.... they have tons of them but all weird sizes..... so then i went over to the pulley section and found the perfect idler pulleys with a perfect 5 inch OD and 5/8" hole with ball bearings. the 5/8" bearing should give me a really strong setup.
only problem was they only had 1 in stock...
my idea is to get 14 inches of 6"x.5"wall pvc, then ill get a foot of 5"x.5"wall pvc (could even use 5" steel tube)
cut the 5" pvc into four 3" sections, cut the 6" into two 7"sections
i will place the pulley in the center of the 6 inch pvc then samwich the pulley with 2 5" peices. this should make a pretty sweet and strong wheel.... then i can cut the wheel down to whatever size i want..... i figure ill start with 7 inch then step down from there till i like it.Last edited by justtorchit; 03-16-2012, 09:51 AM.Originally posted by Ktmracer419some people choose video games
How do you plan on cutting 6" PVC square? (I understand the diagram, I'm just asking because everything is going to depend on how square those pipe ends are.)Originally posted by 04WranglerX View PostAnd if my explaination wasn't good enough, this is what I mean.
I learned how to draft from the school of dickerman, but you get the idea.
Feedback?Last edited by Lumbergh; 03-16-2012, 01:09 PM.
