So I already have a GoPro tube mount made up (dizzy/tim made it) that the gopro mounts to. its purpose is to set the gopro back away from the vehicle to film it in motion.
anyway, it works well enough, except it has deflection in it and tends to vibrate at the end with the camera, making for shaky/jittery imagery. this was predicted obviously and dizzy welded little loops on the tube itself to fasten something to to attach to the vehicle at the other end, another brace basically.
now the mystery is, what should i use for that extra brace? It has to be:
Easily removable, and easily installable, and quick. Cannot be solid really (aka it needs to be length/orientation adjustable)
Basically we need something that will hook on the bar, and attach to the car (presumably tube on a tube chassis) and be tight to brace against vibration at the end...and i need to be able to easily move it between vehicles (easy put on and take off)
what are some ideas for what I can use? we used a ratchet strap in a pinch, but theyre a bit of a hassle and im not interested in that route if i cant find an efficient way to use them, i refuse to believe there isnt a killer option for this out there.
image example:
image example:
