i want a jeep :(
  • i want a jeep :(
    i dont know why, but i want one. i wanna join the flock of wheelers with stock axles and 31s in the worst way. Im almost at the point ill sell my toyota for one. arg. tell me its a bad idea.....
    of course in a year it will be on tons and an atlas with a cage blah blah blah haha. idea now however is to keep it streetable for as long as i can.
    sigh.
    anyone want to buy a 85 4runner with 39's, tons, doubler that puts the rig at 250 to 1? needs some tlc
    Originally posted by gmc4cw
    if someone can look at your rig and still tell what it was, then you have a long way to go before its destroyed. if you continue to wheel it after said destruction then you are truely special. :shock:
    get jeep
    roll on green trail with sis
    profit
      do eeeeet
        Pics of said yota?
          A jeep on 31s may cost you $1000 for a nice one with used tires...
          Does it Yesterday.
          Better yet, I'll trade you a grand wagoneer with a blown engine for an 00-04 Toyota Tacoma with no rust on it.
              good. shit.
              91 YJ: 4.0, 4" lift, 33" TSL's, SYE, Woody driveshaft, cut flares
                for the record, that tree climb in the last pic was accidental. i was in double low first gear and caught me by surprise. i was no where near rolling yet either
                  how much would you sell that yota for?
                    needs work. the mounts for the doubler need gone over, it is flat belly, 24 inch's clearence at the skid i believe. motor needs looked at. no power what so ever, i believe its just the fuse.
                    i just put a psc pump, redtop ultima battery, kill switch, ignition switch and redid the fuel lines to the cell.
                    also needs a new alloy shaft. if someone buys it ill buy the shaft and put it in. its a tank, i just live in an apartment now and no time or space to work on it. id rather have a jeep now i think so most of the stuff can be done in the parking lot haha.
                      as is, 5k. 5300$ and ill deliver Ill throw in the top, the spare doors, and 5 speed trans i have for it.
                        down boy
                          d60 front w/ 5.39's welded
                          sterling rear w/ 5.39s welded
                          PSC hydro pump to tsc ram
                          22RE motor
                          Doubler with the rear case with 4.7 gears giving you 250.1 ratio
                          39's with 2 spares (I think 2, might be 1)
                          5 speed stick with spare trans. You have 22 forward gears with the setup i have.
                          Full exo cage
                          rear chevy springs
                          front toyota rear springs
                          working heat
                          Beadlocks
                          Chrome alloy shafts in the D60
                          drive flanges
                          square tube drive shafts to flanges
                          optima red top battery and kill switch
                          2 spare full doors with glass, 2 half doors with cup holders
                          tire carrier in the back with swing out.
                          hard top that slides on for winter wheeling
                          i cant think of anything else
                            down boy
                            i clearly cant afford it i was just curious
                              everythings affordable
