How to: gear install
  • How to: gear install
    copied from another forum. note this is not the same for all differentials
    There are 4 basic measurements you need to get.
    1) Pinion Depth
    2) Backlash
    3) Pinion Bearing preload
    4) Carrier bearing preload
    Start by removing the differential cover. Make sure you got some kind of pan underneath the axle; gear oil is going to go everywhere. Once you get this far, spin the carrier around until you see the Cross shaft bolt shown here...
    With the cross shaft removed the C-Clip port should be in view, Push one of the axles inward (from the side of the axle), which will reveal the c-clip, remove it. Use needle nosed pliers (or just your hands) to pull the C-clips out. Once the c-clips are removed the axle shafts can be pulled. When you go to pull out the axle shafts, be careful not to put too much stress the bearing seal at the end of the axle tube. Do this for both sides.
    Remove the four big bolts that hold the carrier bearing caps on (shown below), then try and pull on the carrier/ring gear, to where it will pop out. If it’s too tight to be tugged out, a crow-bar to peal out the carrier. You can pry against ring gear bolts on the backside of the carrier. If you tug right on its sweet spot, you can get the carrier all the way out in just one tug, on one side... if you jar up the carrier (i mean, sort of jamming it side-to-side, which you will probably do your first couple times) you will have to pry from the opposite side (which has no bolts to pry on ). Use a piece of wood to wedge the crow bar on, so you don’t ding up the axle housing. Try and not ding up the carrier too much, because it’s easy to make junk out it.
    Make sure mark the bearing caps between right and left. Those caps are machined to match the housing and do not interchange. If you mix them up you can compare the texture of the machined surface on the cap to the texture in the house. Take notice of the tapered sides of the caps, this will contrast to the tapering on the housing
    Setting up Backlash
    Now you want to measure the backlash by putting the dial indicator on the very edge of a tooth on the ring gear, you want the indicator to be perpendicular to the edge of the tooth as you possibly can. If you look closely, some gear manufacturers make a little tapered edge on this section of the teeth, using this area makes pointing the dial indicator very accurate.
    The backlash is the amount of slop in between the ring gear and the pinion; you are measuring that distance. (.008"-.015") is the amount you want. You are going to move the carrier left and right by using the shims in your install kit. . You want to keep this balance so your backlash stays consistent. Make sure you torque the bearing caps to 77ftlbs before checking your pattern...
    Are your shims pissing you off because they won’t stay in the housing when you try to install the carrier? I have a little trick for you! Coat the shim flanges and shims in gear oil so it can sort of glue them together. This is a great time saver.
    The pinion depth is the next measurement you need to look at. Put some gear marking compound on a couple teeth and turn the pinion to get a little pattern.
    You don't need to use a crush sleeve each time you remove the pinion to change shims. It can make things tedious for you and possibly give you a false preload, but most of all leaving the sleeve out teaches you what 16inlbs should feel like. As long the torque it takes to turn the pinion is the same as when you go to set up your final assembly with a crush sleeve, pinion depth will be the same. Just make sure to check it, when you are trying to get a feel for it.
    In general, when you are setting up gears you are mainly trying to measure from the face to the flank of the tooth, a perfect heel to toe pattern usually impractical. The reason i say this is because all housings are different.
    If your pattern seems way too close to the toe, then subtract some shim thickness from your pinion shim. If you are closer to the heel, Add shims. Usually (especially in smaller gear jumps like 3.55 to 4.10) the stock pinion shim should be perfect. My stock pinion shim was a good starting point; with a Jump from 3.27 to 4.56 I was barely too close to the toe for my liking. I dropped the pinion shim by -.002 and it was perfect from there. Remove the carrier and add/subtract the amount in shims on your stock pinion shim to get your pattern
    Check your pattern again, and if you like what you got then you basically done! The chart below, taken from the Yukon gear manual, should be able to help you determine the pattern. The pattern is going to be difficult to read on the coast side (a.k.a ghost side) during trial assemblies, or until you adjust the preload on the pinion and carrier bearings. After the preloads' have been set the pattern should be nice and defined. There should be a nice shaped oval centered between face and flank on the drive side, and on the ghost side there should be a nice swoop across the back of the gear, again centered face to flank.
    Pinion bearing preload.
    You will need a Good breaker bar here. Also an inlb torque wrench that can read as low as 10 inlbs. You probably will want some extra crush sleeves and pinion seals too... Assemble your pinion... shims, inner bearing, crush sleeve, outer bearing, oil slinger, oil seal, pinion flange then finally the OLD pinion nut from your stock gear set. You want to use the old nut to CRUSH the crush sleeve, ill elaborate on this some more in a second...
    Start cranking that Nut, it will take a good 200ftlbs to crush that crush sleeve to specification. An impact may only get you so far, but even the ones with like 550ftlb burst fire won’t get that nut as tight as it needs to go. What you are trying to do it shrink that crush sleeve until the bearings are pressed up against the races. Every Quarter turn you put on the pinion nut, tap the pinion with a soft (rubber) hammer. Then use your inlb torque wrench to check the amount of drag that’s on the pinion.
    When your preload is close (somewhere like 2-5inlbs), remove the old nut, and start over with the new one. Although it will be MUCH easier the second time around, because the crush sleeve is already crushed. Remember to put some lock-tit on there. The reason its good practice to crush the sleeve with the old nut, is because the threads on the pinion nut taper. The threads on the old nut are worn and will loosen up easily, especially with new bearings. There is some debate on this, and ill go by what I’ve always been taught... and that’s to not re-use the old nut.
    It should take 16-29inlbs (on new bearings) to make the pinion move or in other words to correctly preload the pinion bearings. If it goes above that then you have to start over with a new crush sleeve.
    It will take about 2 full turns till you close to specification. That’s not exact, you need to check every quarter turn, but once it gets close it happens very quickly. When you feel drag on the pinion, and maybe you are at 4 or 5 inlbs, only a very slight turn is needed; very slight.
    Is your preload already too tight before you have even crushed the crush sleeve? Check your pinion seal! Not all pinion seals are created equal; this is why I trust BCA brand pinion seals. Brands like motor city and NAPA tend to sit a little tighter along the dust shield, causing excess drag on the pinion. You don’t need a new pinion seal, just find exactly how much extra drag it produces, keep in mind you have that extra amount of drag. Once you start to crush the crush sleeve, just remember to add that amount of drag, to the drag you are trying to measure for you bearing preload.
    Once your pinion is set, reinstall your carrier. Use the shims you decided had the correct backlash and add .005-.007 to each side to preload the carrier bearings. At this point, if your backlash is close but you would like it tighter/looser, then you can add more to one side to balance it out.
    Its going to be a very tight fit, but keep in mind it’s harder to over preload the carrier bearings then to not. Although not impossible, it’s rare because you got to be freggin He-man to press in that tight of a fit. Use a rubber hammer to smack in the carrier. Torque down your bearing caps to 77ftlbs and check your pattern again, just for giggles...
    If your pattern is correct, and you feel comfortable with your preloads, then get that sucker back under the truck! You're done! Well...
    The Break-In Period
    This is the most crucial part of the gear install.
    Gears have to be broken in properly or they will fail within the first 500 miles of installation. Most gear sets fail because people neglect that they need to break in the gears.
    It’s pretty easy. Drive for no more then 10-30 minutes at a time. Make sure you give your differential adequate time to cool after driving (at least an hour).
    Drive normally. You should be alright gassing the petal a little bit, just put any extreme stress on the differential until the 500 break-in period has expired.
    Make sure you set your Trip meter after your install, so you know when the 500 mile mark comes. When it does, change the gear oil. You should take notice of any metal shavings and debris in the gear oil. If anything seems a bit excessive then closely examine the (with gear marking compound) gears and make sure they are meshing properly. You never know, you might have gotten some debris in the shims and gotten a false preload setting?
      pinion depth gauge
      http://www.circletracksupply.com/pro...&cat=88&page=1
      dial indicator
      [ame]http://www.amazon.com/Grizzly-G9849-Magnetic-Indicator-Combo/dp/B0000DD0VA[/ame]
      torque wrenches can be borrowed most reputably mechanics have them
        One thing i can contribute: i think a problem people have is putting on too much marking compound on the gears. it can give you a false read (thinking your set-up is bad). I've seen it happen twice
          I actually have a DVD that walks you through step by step VERY in depth how to install gears... If anybody wants it let me know and Ill make a copy.
          You better decide if you are hanging on the cross, or banging in the nails
            interested in a copy.
              k Ill try and dig it out(we just moved) and make copies to bring this weekend.
                Cool, thanks man.
                  crush sleeves are the devil....
                  after 3 broken tools (1/2 breaker bar, 3/4 breaker bar, huge pipe wrench.)
                  14 bolt crush sleeve tool.... THE BAW
                    pretty determined this is the best write-up i've read so far. thanks rj
