Tons of parts
  • Tons of parts
    Unfortunately its time for me to part out my Jeep so here is what is for sale.
    High pinion, kingpin Ford Dana 60 from a 79 F350. Will bolt right in to any long armed XJ, TJ or ZJ. Has Clayton high clearance axle brackets that were installed by Clayton. 4.56 Yukon gears with extended lifetime warranty, Yukon master install kit, Detroit Soft Locker, Warn Premium hubs, Blackbird Customs disc brake brackets, Chevy ¾ ton rotors, calipers, pads, wheel bearings and seals. Banditt Off-Road 1 ton steering (1.5” DOM with .25” walls needs a new rod end). Wms to wms is 69”. $2000 SOLD
    Rear axle is a 14 bolt with a Detroit Locker and factory 4.56 gears. It also has Clayton high clearance axle brackets and truss that were installed by Clayton. Also has 1350 yoke with u-bolts, Ruff Stuff Specialties disc brake brackets, Chevy ¾ ton rotors, and hubs. Wms to wms is 67”. $700 SOLD
    AMC 360 that runs perfect! Has an HEI distributor, Taylor 8mm wires. Complete from intake to oil pan. $200
    Rust-free 1994 YJ frame with complete Clayton long arm coil conversion. Frame was modified and suspension was built by Clayton Off-Road. Includes long arms and trac bar with Johnny Joints, springs and front shocks. A TJ (1997-2005) front axle will bolt right in, the rear is triangulated but lower control arms will bolt right in. Just bolt in your axles or just use the long arms for a TJ. No motor mounts. Asking $1500 or best offer. SOLD
    Ford NP205, twin sticked 205 with billet knobs. Rock solid. Asking $200 SOLD
    5 - 37" Super Swamper Irok's bias on 8 lug wagons. 75% tread on 4, one brand new with sticker still on it. Comes with lifetime, no questions asked free replacement up to 50% of tire life $800 SOLD
    2 black with grey MasterCraft Rubicon seats with Lumbar. Perfect condition, only 1 run on them. Part number MCS523207 $550 set SOLD
    2 black MasterCraft 3x3 5-point harnesses. Also in perfect condition with only 1 run on them. Part number 11000 $125 set BOLD
    RCI 15 gallon aluminum fuel cell with sending unit (never hooked up the sending unit but it should work). Comes with Autometer Ultra-Lite fuel gauge and AN fittings $150 SOLD
    YJ doors in red complete with glass $150 SOLD
    1988 YJ windshield with VIN and TITLE - $150 SOLD
    YJ hard top in black with factory black tinted windows. No cracks. $300 SOLD
    Bestop Sun Rider soft top in black. Complete, ready to bolt in. No rips in top and in great shape. Will come with everything to bolt in. Fold it all the way back or just flip the top over the driver and passenger back for some sun $250
    YJ windshield frame in red. Rust free and comes with the wiper motor $100. Bad glass SOLD
    Radiator for AMC or Ford V8’s in a YJ. $75
    Currie Anti-Rock for YJ/TJ $200SOLD
    Poison Spyder Rocker Knockers with slider bar. Comes with mounting hardware. Needs paint. $150 SOLD
    Full 1/4" YJ crusher corners complete with all hardware and TJ rear flares. Uses factory tail lights. Mint condition. $200 SOLD
    Will sell rust free 1995 YJ tub with full corners and sliders for $600. Needs paint. SOLD
    YJ tailgate - $50 SOLD
    Tom Woods 1350 double cardan rear shaft with flange- $150 SOLD
    Tom Woods 1310/1330 shaft 35.25" - $100 SOLD
    Warn 8000 winch - $200 SALE PENDING
    Extended, stainless brake lines - $35 full set SOLD
    YJ Power steering box - $30 SOLD
    Rear seat belts from a 95 tub - $25 SOLD
    YJ hood, no rust - $25
    2" body lift blocks - $20 SOLD
    JD2 Model 3 tubing bender with 1.5" and 1.75" die, air over hydro ram and stand. Barely used. Asking $800 SOLD
    Pics on request.
    The entire Jeep is still together so if you need anything else, everything goes. Will sell as complete vehicle also. Let me know if you are interested in anything. Located in Southington, CT but can deliver within a reasonable distance.
    Steve joker4ink@cox.net
    88 YJ...kinda. Clayton Hard Arms, V8, 1 tons w/Detroits, twin sticked T-18/NP205, Irok's, MasterCrafts, fuel cell, multi-colored
    PM sent
    HOONIGAN FOR LIFE
    OLD 4X4'S NEVER DIE!!!!!
      you make me sad
      i sure wish i was building a yj.
      anyway.if you still have the bender in a few weeks. it's mine
        http://174.132.165.188/~siswill/foru...ead.php?t=3099
          It makes me very sad too. I've got a couple things that are more important that my Jeep right now though. I'm not done wheeling, it just might be some time before I'm building again.
            pm sent
              sorry to hear you're parting out your rig...sounds like a monster but....happen to still have that warn 8000? if it's in good working condition, i'll take it!
              i'm in bridgeport..not far from you
                I'll take the seats/belts! PM me details! You want me to Pay Pal you?
                HOONIGAN FOR LIFE
                  any chance you may wanna hold that winch for me for a little bit steve?
                    steve is the anti rock in all working condition and what not? I will pick that up from you if alls good on it.
                    You better decide if you are hanging on the cross, or banging in the nails
                      id be interested in the 125 dolla pair of seats....
                        those are just the harness, no seat
                          id be interested in the harness possibly lol
                            Still have Anti-Rock? Dibs if things fall through with Cody
                              2nd dibs on winch
