seats.
  • seats.
    Will zj seats fit into an xj, Are they direct bolt on or will they need brackets. Those seats are sooooooo much more comfortable then mine
    as far as i know, you need the swap the brackets from your xj to the zj seats, then they will bolt right into your xj
      Both ZJ and WJ seats will bolt into your XJ, you just need to swap the XJ seat tracks onto the grand cherokee seats. 4 bolts for each seat. I'd look for a seat with manual recline since you will still be able to fully control the seat manually. If you find an electric recline seat you can control back and forth movement manually but will have to wire power to the recline motor.
      -Josh
      2000 Jeep Cherokee 2" lift, 30x9.5 General Grabber AT2
        what about back seats? Just out of curiosity?
          figured i toss some pics up for ya
          here the difference in brackets
          XJ seat on left
          ZJ seat on right
          the brackets interchange though 4 13mm bolts
            might have to take a ride to chuck and eddies
