so i got a 96 cherokee and the drive shaft keeps coming out of the yoke on the rear i put brand new u joints and straps bolts its all new and i lost it again in the woods yesterday what could be the problem or a way to fix this any help would work thanks guys
drive shaft
I'm guessing you have a lifted cherokee based off your name "liftedcherokee"
Did you ever get a longer drive shaft? What did you expect?
The common fix is a SYE slip yoke eliminator then buy a drive shaft the correct length with a longer slip yoke.
The OEM T-case slip yoke is only so long, not meant for long travel suspensions, especially with leafs.RCrocs #123 Brown CJ-5
are the u-joints breaking? it shouldnt slip out at all at the axle end. if it is, theres something wrong with your yoke. maybe holes stripped outhard to tell without looking at it
so what are you trying to say the u-joint is not breaking but rather falling out of the yoke?
So the straps are failing?
Is the yoke damaged?
Is the yoke holding the u-joint tight to begin with?
Did you upgrade to u-bolt yoke?
Maybe you have too much axle wrap, could need a ladder bar.RCrocs #123 Brown CJ-5
I think pics would be 100000% better here.Jeeps don't get stuck ... they just take a nap when they are tired of being awesome
93 2DR XJ 8" lift D30/D44 4.56's 35" MTRs IRO Y-link Build:http://sisoffroad.com/forums/showthread.php?t=9658
Eric
Originally posted by JeepBabiiXJ View Postholy god lord jesus.
take it to a mechanic.best response so far
I am honestly confused as to how this is physically possible. So.........you just drive down a trail and your rear drive-shaft legit falls out onto the ground and you don't even notice and just keep on truckin?!?!?!? Come home look under your rig and "dammit bubba it happened again. Go get a new one out that there pile in the back yard." I don't even know how it could fall out of the yoke without some real noise and it would put up quite a fight. Unless you aren't even using the straps!?!?Jeeps don't get stuck ... they just take a nap when they are tired of being awesome
Eric
