Go Back   SiSOffRoad Forums > Swap Shop > For Sale
Old 04-05-2017, 08:08 PM   #1
mcguyver_xj
mcguyver_xj is an unknown quantity at this point
Default Modified '99 xj from South Carolina
Thinking of selling my project for reasons... it's a 1999 xj that has been in SC all it's life except for the last two or so years but it has not been driven in the snow, it was a 4.0 auto 2wd with 280k and a blown motor...
Drivetrain:
Used 4.0 with 150k new tune up, oil filter adapter orings, valve cover gasket, water pump and thermostat... tranny is an aw4 out of a 2000 with 160k has fresh filter and fluid and an auxiliary transmission cooler... tcase is a np231 with 160k and an sye with fresh fluid and a tom woods rear driveshaft...rear axle is a 29 spline 8.25 with 4.10s, new axle bearings and seals, Spartan lunchbox locker, and a Solid diff cover, front axle is a hp30 with big ujoint shafts, 4.10s, aftermarket uca mount and lca mounts with skids, new uca bushings, lockrite lunchbox locker, Solid diff cover and Synergy Suspension ball joints...
Brakes: stock front, new rear drums and shoes, new Crown performance extended stainless steel lines
Suspension: Rubicon express front coils with small .75 spacers, Bilsteins all around, TNT long arms with full belly pan and tcase skid, Clayton leafs and rubicon express boomerang shackles, rubicon express hd trac bar and bracket and brace...
Steering: stock box, stock pump with 4.5 psc pulley, JCR steering box spacer, Boostwerks steering box brace (amazing piece) custom or aftermarket crossover heim steering
Other: ORS Fab front stubby winch bumper (small fan shop on pirate4x4) JCR quarter guards, factory gas tank skid, factory rear tow hook, T and M Fab mid subframe stiffeners, 35x12.5x15 Goodyear MTR Kevlar tires with under 1k miles (bought brand new last year have 5 wheeling trips) on 15x8 Cragar V5 rims
Sent from my iPhone using Tapatalk
mcguyver_xj is offline   Reply With Quote
Old 04-05-2017, 08:11 PM   #2
mcguyver_xj
Jeep has no carpet po must have spilled lots of soda and stuff cause the carpet was trash it will come with one I got out of another xj, needs a headliner, comes with the wiring harness for factory fog lights, comes with an uninstalled cb radio and antenna and mount...
Old 04-05-2017, 08:13 PM   #3
mcguyver_xj
The rocker panels need to be done they aren't rusty just a little dented from off-roading but the jeep comes with aftermarket rockets from a small company owned by a personal friend called Spadano Enterprises I can provide pics of these things installed and in use and they can handle a ton of abuse I just never got around to installing and I have installed them on two friends xj's
Old 04-05-2017, 08:14 PM   #4
mcguyver_xj
The jeep actually has no rust btw
Old 04-05-2017, 09:39 PM   #5
mcguyver_xj
Oops most important part jeep is in Holyoke, ma and asking $7500 obo
Old 04-24-2017, 08:27 AM   #6
mcguyver_xj
$6800 obo
Old 05-04-2017, 11:45 AM   #7
mcguyver_xj
Bump $6500 obo the season is starting and this is pretty much ready to wheel
Old 05-19-2017, 11:42 AM   #8
mcguyver_xj
$6000 obo
