lifting
  • lifting
    right now i have a stock set up on my 98 zj if i put on a 2 inch lift would i be able to put on 32's
    TeamRedNReckless
    98 zj 4" 31's no fenders or doors -Retired-
    4x4 Abbreviations
    you would have to trim, with a 3.5 in lift you can fit 32's with just trimming the front bumper, and the bottom piece of the bumper that runs along the width of front end
      any guides or forums already done up on showing how to do that
      TeamRedNReckless
      4x4 Abbreviations
        I'm sure theres plenty of write ups on here that will show/tell you how to do it. Just search around in the build threads, Swamp thing just trimmed his i think.
        1981 CJ8 - old & dumb
        1988 Cherokee Limited - The Real Cherokee
        2001 TJ Sport - DD
          well i dont really want to trim so if i got a higher lift would that be a possibility
          TeamRedNReckless
          4x4 Abbreviations
            dont rly want to do any serious rock crawling only trail and a lil bit of mud its going to be for show too so i want it to look nice
            TeamRedNReckless
            4x4 Abbreviations
              With a 3 in lift i used to run 32's and only rubbed a little bit. Its all about your bumpstops too, bigger the stop the less likely you're gonna smash a fender with a tire, but also less flex. I think a lot of guys on here like to keep a lcog so they do that. There should be a couple threads on that too.
              2001 TJ Sport - DD
                if you're running a dana35 in the rear i wouldn't go bigger than 31's
                  3.5" with 35s
                  you can make 2" with 32s work, but i really dont even like bb's in the first place, there kinda just a waste of money cuz most likely you will upgrade to springs eventually.
                  do a front to rear spring swap an buy any 3-4" front spring you want,i run a ome 3.5". you will need at least a rear track bar drop bracket an a new adj front one, i would suggest a double shear one so it doesnt blow up in five min of wheelin.
                  97 zj- frankenstein 3.5", 35 stt's.
                  92 240sx- coilovers,full adj arms bla bla bla. 50trim t3/t04 soon
                  xj- need one
                    This is my friends jeep I put a 2" bb on and 31x10.5 mickey thompson MTZ's.
                    All I did was trim the front bumper a little bit. He probably could put 32's on right now. We actually put my 35's on for shits and giggles, but when we let his jeep down the fenders were on the tires.
                    But with enough cutting and bumpstopping you can make anything work.
