oxygen sensor help
  • oxygen sensor help
    I am replacing the rear O2 sensor but i do not have the connector anymore. Im using a universal O2 sensor and need to know which wires to connect. I got a wiring diagram off Alldata that shows the following
    dark brown/white-Fused Automatic shut down rely output
    black-Ground
    brown/yellow-sensor return
    tan/white-O2 sensor 1/2 signal
    the sensor has 2 white wires which are for the heater circuit, a black wire for the output, and a grey wire for the ground. I obviously have the ground figured out but the other 3 im not sure which ones to connect. Any ideas would be appreciated
