ZJ V8 steering
  • Even
    replied
    Originally posted by 1-Ton-XJ View Post
    No he was talking about the steering hitting objects and i said that is not steering weakness related
    I see the point you are trying to make, but unfortunately, that is steering weakness. At least as far as wheeling is concerned.
    Leave a comment:
  • Even
    replied
    BTW, poor spotting and hitting trail obstacles happens. If it doesn't, you either wheel like a puss, or have the greatest spotter wheeling has ever seen.
    The idea of upgrading steering, is to prevent breakage. If your theory held true, you could say the same for control arms, skid plates....hell, any armor that you'd like to throw into the equation.
    Leave a comment:
  • 1-Ton-XJ
    replied
    Leave a comment:
  • Even
    replied
    Precisely, you have your tires between two rocks, and you are trying to turn and drive up one of them....the larger the tire, the more leverage is on that tie rod.
    If people are breaking them on trail obstacles, thats a result of poor spotting and driving...NOT steering weakness
    Correct me if I'm wrong, but didn't you contradict yourself?
    I agree, the larger the tire, the more leverage. I've personally seen large tires completely fold stock steering, with no previous damage. How exactly is that not steering weakness?
    Leave a comment:
  • 1-Ton-XJ
    replied
    Leave a comment:
  • HeavyMetal
    replied
    The more weight and leverage there is on your steering...along with the added stress of turning a locked vehicle vs open.....simple physics
    and what about rocks, stumps, small children, so on
    ive seen steering bend or break via trail obstacles a lot more than just via the jeep itself
    Leave a comment:
  • 1-Ton-XJ
    replied
    i for one am curious as to how tire size and if youre locked effects whether or not you should have stronger steering links haha
    Leave a comment:
  • iant333
    replied
    I have V8 ZJ steering, its not too bad, but the advantage to the stock one was if you bent it, it could be bent back with a crowbar, cant do that with the ZJ stuff and its not quite strong enough to never bend in the first place.
    Leave a comment:
  • HeavyMetal
    replied
    Why are you doing a 1 ton setup btw? Do you plan on running more lift, larger tires and lockers? If you are sticking with the 33 ATs and Open/Open then its a waste of money.
    Leave a comment:
  • justtorchit
    replied
    lol wut
    i did the v8 stuff a long time ago. it sucked.
    my sleeved stock steering lasted longer.
    just keep saving
    Leave a comment:
  • 003brian
    replied
    i would just save for 1 ton man.
    i have a v8 zj an the steering isnt all that beefy, even with good tierods i would still be sketched out about breaking it.
    Leave a comment:
  • LittleD
    replied
    Planning on 35's locked up front. and at around 6 inches of lift up front, i kinda need it
    Leave a comment:
  • 1-Ton-XJ
    replied
    You cannot flip the drag link, you can flip the tie rod. I snapped a drag link in half and bent the tie rod up under my axle and my tie rods were perfectly fine.
    Leave a comment:
  • Even
    replied
    I'm sure you could run it OTK if you really wanted. You will still have to ream out your knuckles from the top to accept the TRE's though.
    Unless you find it for less than $30, I would just keep saving for 1-ton. The solid tie rod is nice, but you're still stuck with tiny ass TRE's.
    Leave a comment:
  • LittleD
    replied
    Sorry for the confusion, i meant can flip the tie rod ends for otk, but if i have to get other shit to do it, ill leave it utk untill i buy a 1 ton setup. I've heard people getting them for like 20 bucks so thats why i ask
    Leave a comment:
