show us your welds
  • #31
    getting better with this thing
    ha
    • #32
      I haven't used a tig in about 7 years but its coming back.
      • #33
        Nice is my steering next.
        • #34
          Bring it down! I just built an awesome setup. Wish I got some good pics. Customer will be sending some soon I hope.
          • #35
            TIG welding sway bar relocation brackets? Why not.
            • #36
              attached to the axle and a bit more useful.
              • #37
                ive been getting into welding more recently, so much easier than bolting things together for the small projects i do. I biggest tendecy is to hold the puddle to long and burn thru
                here is some from a lawn mower plow frame I started at lunch
                markup of brace's 60 degree angle cut on one side, need to cut other side and then weld in center+plow frame (old atv plow)
                • #38
                  Axle building with some final pass TIG over top of a smaller root TIG
                  • #39
                    welded up a JCR build a bumper for my brother and practicing some welding.
                    bent and tac welded it all up at the shop then brought it home to final weld.
                    changing the settings as i went along with weave pattern, trial and error.
                    the end pieces that take up the gap between the bumper and tail lights i did last and came out the best.
                    • #40
                      Ok now I really want to play. Spent the last three weeks practicing almost every night tig welding. Now I get to really play.
                      Here's a fuel tank
                      Today I spent four hours in a 8 inch by 36 inch box welding all new cross members. All spool gun work was absolutely miserable.
                      This was my area to work
                      Dizz dizz go sleep sleep
                      Driver 4677 FSM vehicle
                      • #41
                        On that tank did you run a root pass before that? Looks way better than what i can do on aluminum.
                        • #42
                          No I just ratchet strapped a piece of flat 1/8 aluminum to fit the contour of the tank and laid it in there. There's a few shifty spots cause the new kid doesn't understand don't open the door for any reason and would walk outside and leave it open lol.
                          • #43
                            hahah "shielding gas? what's that?"
                            • #44
                              next meet and greet we will do the welders strength test see who can actually pull it off
                              • #45
