Go Back   SiSOffRoad Forums > Swap Shop > For Sale
Old 03-26-2017, 11:34 AM   #1
mcguyver_xj
mcguyver_xj is an unknown quantity at this point
Default Rust free '99 four door xj
Selling my fiancÚs xj we bought in North Carolina off my friend... it's a 1999 with 220k runs amazing and has lots of new stuff under the hood, interior is pretty clean minus a saggy headliner and steering wheel is becoming a bit ratty... has really good tires on wj rims... asking $2300 or best offer we are selling as we want to get into a Subaru miles will go up as she drives it everyday
Has power windows, power locks, aftermarket CD player with Bluetooth/ handsfree the mic just has to be retaped down,4.0, aw4, 8.25 rear perfect to be built into a good crawler or keep as a clean driver that has tons of life left
Sent from my iPhone using Tapatalk
mcguyver_xj is offline   Reply With Quote
Old 03-26-2017, 11:35 AM   #2
mcguyver_xj
Some underside pics to prove not rusty
Old 03-26-2017, 11:43 AM   #3
mcguyver_xj
List of new stuff:
Performance exhaust manifold, upstream o2 sensor, fuel injector o-rings, valve cover gasket, oil filter adapter o-rings, serp belt, water pump, thermostat and housing, all coolant hoses, radiator, heater core, tune up, rear brakes, power steering pressure line, motor mounts (which I think are junky fresh out of box engine vibrates when cold)
Things it could use would be are honestly just a 4wd swap it did ok with these tires and knowing something about driving in snow... it comes with a 4x4 aw4 with under 100k miles and a torque converter, a boostwerks np231 shift linkage, and a np231 floor shifter all you need is a tcase driveshafts and a front axle and a tiny amount of work I four wheel drive swapped my off-road rig
Old 03-26-2017, 11:47 AM   #4
mcguyver_xj
Sorry almost forgot located in Holyoke, MA
Old 03-27-2017, 02:23 PM   #5
CntStpTheStnk06
CntStpTheStnk06's Avatar
CntStpTheStnk06 is an unknown quantity at this point
Give me a call when your ready to let her go
CntStpTheStnk06 is offline   Reply With Quote
Old 04-18-2017, 11:45 AM   #6
mcguyver_xj
Messaged you on naxja don't have your phone number
Old 04-22-2017, 03:46 PM   #7
mcguyver_xj
Just had a new trac bar and tie rod end installed $2k obo
Old 05-04-2017, 11:45 AM   #8
mcguyver_xj
$1800 come get it
Old 06-15-2017, 02:20 PM   #9
mcguyver_xj
just got a fresh passing inspection sticker
Old 06-18-2017, 09:09 PM   #10
mcguyver_xj
Sold
