Go Back   SiSOffRoad Forums > General > The Shenanigans Forum
Old 03-23-2017, 09:24 PM   #16
My thoughts based on everything I've replaced over the years. I'm sure I'm missing some:
- Exhaust Manifold is a must.
- Fully redo cooling system if over 100k miles - Radiator, water pump, thermostat, hoses, etc.
- New OE Mopar sensors (Or a good aftermarket equivalent) - Crank, temp, oil pressure, throttle position, MAP, IAC, O2s, etc. Anything that can effect the running of the jeep. (Keep old as spares).
- Keep a spare A/C compressor delete pulley with me at all times.
- Check all rubber vacuum/EVAP lines for cracks.
- Motor Mounts - Brown Dog Rubber if you must.
- All fluids changed - Trans, diffs, t case, etc
- D30/C8.25 are plenty fine for anything up to 33s. - 4.56 or 4.88 with 33s.
- Chances are the valve cover gasket and oil filter adapter o ring leak. - replace them.
- A good battery - Probably an AGM of sorts - Odyssey, Optima, DEKA, etc
- New alternator - keep the old as a spare
- New belt and idler pulleys.
- Filters - No FRAM bullshit - NAPA Gold or Platinum.
- Fuel Pump
Virtually replace anything that impacts performance, "Should" be replaced or has a higher failure rate after 100,000ish miles. I replaced a lot of stuff "just because" and I was never left stranded. I also never threw out anything that I replaced that was still "good."
And a little NAPA Know How
Old 03-24-2017, 12:48 AM   #17
Great reply.
Old 03-24-2017, 08:29 AM   #18
Lawn Guyland
Lawn Guyland's Avatar
Totes MaGoats
Lawn Guyland is an unknown quantity at this point
Send a message via AIM to Lawn Guyland
I'd buy a WK2
soon-to-be mrs. heavymetal from jeepforum
2016 hydrometal jku
Originally Posted by hoggie101 View Post
Lawn Guyland is offline   Reply With Quote
Old 03-24-2017, 08:36 AM   #19
Originally Posted by Lawn Guyland View Post
I'd buy a WK2
I like her idea....
Old 03-24-2017, 02:05 PM   #20
Old 03-24-2017, 03:56 PM   #21
Originally Posted by Pedro View Post
I like her idea....
You dont even wheel a JK, of course you'd want a WK2
Old 03-24-2017, 04:41 PM   #22
Old 03-25-2017, 07:56 AM   #23
Are you saying I'm less of a man because I don't want to bang up my brand new $35k JK that I need to work every day?
Old 03-25-2017, 10:16 AM   #24
I'm saying whatever you want me to be saying it would appear!
Old 03-25-2017, 11:15 AM   #25
hippie metal
hippie metal's Avatar
Bleedin' Gasoline
hippie metal has a little shameless behaviour in the past
Send a message via AIM to hippie metal
Originally Posted by Bigbike View Post
Streetable tires??!?!??! YOU PURPOSELY BOUGHT SHITBOX INTERCO TIRES! YOU DID ALL OF THIS TO YOURSELF
Lol at all caps
This thread is what i would change. And youd buy them too if you found a BRAND NEW set of 38s for 600 bucks. Id have been an idiot not too. They are great offroad.....dicks on the street
Looking at kevlar MTRs, MTZs, or STTs in the 37" flavor
Originally Posted by HitItWithSomeSpeed View Post
Originally Posted by Zullius Caesar View Post
hippie metal is offline   Reply With Quote
Old 03-25-2017, 12:36 PM   #26
Odinthor
Odinthor's Avatar
Odinthor is an unknown quantity at this point
Send a message via AIM to Odinthor
I feel inadequately experienced to answer this question. Check back in 10 years
Amherst or Bust!
02 TJ
2.5" Lift
Odinthor is offline   Reply With Quote
Old 03-26-2017, 07:39 PM   #27
Old 03-26-2017, 07:44 PM   #28
I guess we will agree that the things someone does to a Jeep that doesnt intend to wheel it are:
A. Buy a lift
B. Install aftermarket steel bumpers
C. Buy bigger tires
Old 03-26-2017, 08:25 PM   #29
A. Buy a lift
C. Buy bigger tires
Old 03-26-2017, 08:47 PM   #30
Buffalo Phil
Buffalo Phil's Avatar
Propaganda Machine
Buffalo Phil is an unknown quantity at this point
Send a message via AIM to Buffalo Phil
Your Matrix memes are stupid.
http://sisoffroad.com/forums/image.php?type=sigpic&userid=10&dateline=1233876272
Buffalo Phil is offline   Reply With Quote
HTML code is On
