HHHHWhite Powa Comanche
    it's not a show car i wouldn't worry about perfection. shortening the frame?
      I'm not sure. Plans are right now not to do that but plans are always changing so we will see.
        A pillar. This will tie into my unmade rocksliders.
        B pillar tie ins. Also running a piece up and over the transmission hump and welded to the unibody there too.
        Dark pic of the roof.
        Pretty much got all the bending i need to get done finished. Now i need to waste another 50ft of DOM somewhere haha
          Reinforcing the hell out of this rig. Been inspired by jeepspeed builds for reinforcement ideas.
          Removing the stock suspension mounts and folded and welded the pinch seam and then welded a reinforcement plate over it.
          Reinforcing the sides and underneath. Using LII 1/8 plates on the outside and plating the inside with 3/16 steel. Welded the seams on the unibody and welded the frame/engine plates to the body and reinforcing that.
          Also plated over where the coil sits in up top...Maybe ill mount some air bumps to it someday.
            Finished off the interior cage. Will be adding harness cross bars when i get that far. Also tying the cage to the body with dimpled plates.
            Overhead of the engine bay plating.
              [IMG][/IMG]
              all plated today. going to figure out the front crossmember this week.
                Rear axle is in. Gotta get the long arms installed tomorrow along with the front axle.
                Powertrains out of the cherokee, needs a new exhaust header so an ATP unit is on the way.
                Also have some corbeau baja ss seats en route to cradle my fatass.
                  decided to make the front crossmember and pull the cherokees dash and what not.
                    This is a build im going to be watching for sure. Sweet job man!
                    98 xj, 4.0, AW4, 231 AA SYE, 4.5"RE/RC, CA drop brackets, 33s, and some other stuff
                      doin work!
                        New sweet seats came in today
                        New ATP header
                        Last day of work is tomorrow and i need to haul ass on this thing before i move back to utah at the end of the month along with EJS.
                          did you reread 50 Shades in the seats?
                            Sponsored by Tube Socks Worldwide?
                            HOONIGAN FOR LIFE
                            OLD 4X4'S NEVER DIE!!!!!
                              done?
                                Wow great build!!
