very strange turn signal issue
  • very strange turn signal issue
    My rear signals are really goofy as of late.
    Left turn signal front is peachy....rear will occasionally to quite often blink both sides.
    Right turn signal flashes only the right side but really fast (like when you lose a bulb) ....hazard circuit works fine. Suggestions? Kinda seeing a trend as the relay or the signal switch....but if either of those are bad would it really make it that goofy?
    The switch in the column is bad is my guess. I had to replace mine it was like $40
      I'll start there then. Reading that is something quite common on late models
        It is. It took a half hour
          Drive it more. Mine does that every sppring. By summer she is fine
            Use hand Signals.
              Mine does this just different. In the spring when I hit the brakes the parking lights turn on.
                Originally posted by cherokee-at-16 View Post
                Use hand Signals.
                I like both of those ideas.....
                  try the relay...mine just did dame shit two weeks ago
                    so far so good....hoping it stays this way.
                      Make sure the grounds are good.
                      If it has a bad ground it might send the power through other lights looking for gound.
                      We have seen this issues on certain cars, like brake lights that will light up every light etc.
                        yeah i checked that stuff out pretty extensively actually. all seemed well, plugged in a new relay and seems to be good so far. which of course is a huge plus because i HATE chasing electrical gremlins
                          hmm relay replaced, was good for a day back to doing it in the rear signals again. signals all work at normal speed however. guess i have to chase some wiring.
                            Switch?
                            Originally posted by Lawn Guyland
                            Originally posted by Zullius Caesar
                              Originally posted by hippie metal View Post
                              Switch?
                              Guess that's the next step. Kinda makes sense-ish.
