box with big wheels thing i'm making
  • box with big wheels thing i'm making
    well new to this specific forum and following the advice of some people from here i'll start a build thread. i know most here don't like NAXJA but i have a thread there dating back to December 2012 that i'd prefer to not re post here so i'll just sum up a few things.
    http://naxja.org/forum/showthread.php?t=1094425
    bought a 99XJ that had a decent amount of stuff done to it by the prior owner Ryan Weaver who knows a few people in the XJ crowd.
    from my original post December 30 2012
    99 XJ Limited, D44 rear, built up D30, 35s, bumpers, winch, rubicon express 5.5, 4.56s, Aussie lockers front/rear, WJ knuckles, custom high steering, labarron hood vents, and some other stuff i don't remember.
    as it sat when i bought it
    the front end is completely slopped out, did 2 bushings in last weeks snow storm out side. was going to upgrade to the adjustable rubicon lower arms but got in touch with a member here and picked up a pair of Clayton Long arms so those will be on soon.
    spend all yesterday and night redoing the rear with new seals which were SHOT!! no rear brakes right now since the seals were so bad it messed them up but i'm not going to use them anyway.
    already have parts to install.
    Clayton long arms
    Ford Exploder rear brake mod
    52in LED Vision X light bar needs to get wired in
    then just work the kinks out.
    almost doesn't fit in the garage to work on it, i can only jack the wheels about 4in off the ground before the roof hits part of the storage racks we have.
    and Bomb doggy Books hanging out while we do a tune up
    plans.....
    fender flairs
    rock sliders
    low pro roof rack to mount light bar to
    clearance cut fenders more for the tires
    get heated seats to work right
    fab up a built in dog bed in the back for the pooch
    long arm installing
    early Feb i was aimlessly wandering around the woods and power lines where we used to play paint ball
    mid April i replaced the RE straight track bar that was on it, the himes were slopped out
    the fenders weren't trimmed as good as they should have been to clear the 35s so..... more fab work with the help of my bro.
    it's ok, he's an engineer. he thinks he knows what he's doing
    Before those pics were taken Alex is walking around looking for his welding jacket
    "Hey is my Weldon jacket in my jeep or my other jeep?"
    "You don't have shoes on" -me
    "Oh"
    (puts helmet on, tarts to weld)
    random late night in mid may
    finally NICE OUT!!!! took the doors off.... lost one pin and 2 spacers
    picked this sweeeeeeeeeet low miles (85k) 4.0 up from a guy at work for some booze...... ya, about those "low miles" hahahah
    some real nice looking bearings, think i'll just clean them up with some scotch bright and run em' again.
    Brought the 4.0 to the shop, checked it.... Like everything is bad hahah.
    2 bent rods, 2 five over pistons, bad crank, so this is gonna take a little longer
    cleaned up the valves and reground them.
    a few hours of playing with 16 holes and more best head grinding
    block is ready for line hone, boring .20 over and final deck to even out the piston depth.
    some axle work. stripped a stock D30 i picked up off CL for $50
    now for the real "progress"? not sure if that's the right word.
    custom jeep holder upper i made
    little bit of axle building anyone?
    the guy used one of those huge blue welder things with the gas tank, no idea why as i mean a $200 110V MIG from Harbor Freight with flux core does exactly the same thing..... right?
    hover mode..... ON!!!
    ANOTHER ass from Mass said he was coming to pick up the entire suspension and both axles so while i was out of state my bro pulled the rear and got it ready for him. he never showed up or responded to texts or calls. Hudson now has the axles for his build, kids got potential and isn't retarded. seems cool.
    some rust on the floor, DAMMIT!
    all patched up, welded, painted and then dynamatted
    the passenger side will get the same thing done this weekend.
    axle came back from the sand blast guy last week, painted it with some nice bed liner paint so it doesn't chip easy then put in the ball joins and upper Jonny joints thursday night.
    now... for the trolling post
    over on NAXJA one of the guys joked saying
    "i bet it'll handle really good with 6 track bars"
    i told him the other 5 holes are for steering stabilizers but, i got a better idea.
    working on the new track bar system, looking good so far but haven't had much time to mock it up all the way today.
    lets watch the but hurt flow
      Saredo, nice fab, but I have a question, why put to much into a 30? It seems like a waste.
        Some late night motor jobin'
        And some Ferrrrd 9 building too.
          The hp dana 30 is a GREAT platform, if you're planning on only running 33-35" tires max. The ring and pinion has plenty of strength, and upgrading to the shafts with the 760 u-joint (same as a d44) gives you an axle capable of handling what you need.
          I'm not a huge fan of front 44's because for how much you'd dump into it in order to have a badass one, it wouldn't have been that much more to have built a 60 which is much stronger.
          That being said it still all depends on building an axle to suit your style of wheeling and what you want to be able to do.
          Also....... that's best high clearance axle bracket kit on the market, installed by one badass dude in a yeller jacket if I may so myself
            Isn't it called a Dana "30" because uou can run up to 30 inch tires? Like how the Dana 35 can handle up to 35 inch tires all day..... Right?
              Cranks getting all polished and cleaned up then measured to make sure it's in spec.
              While my brother is doing that I'm figuring out how this ford 9 thingy goes together
              Backlash set to just over .008 today, Thursday ill have time to set the pinion depth and get this thing put together.
                Finally working on this toilet again.
                9 center is all done, waiting on leaf perches to arrive and figuring out a leafspring bushing problem. Then the ass end is done.
                D30 is under the front just waiting on a long arm to mock it up and see where the spring pads need to be welded to.
                Major progress today on the new 4.0.
                Block is line honed and bored 20 over
                Prepped the rods, glass bead, magnaflux, cut the caps, cut rods, new ARP rod bolts and stretch checking. Will hone out to size next week.
                Put the rear toolbox back in, had this tank laying aroun so I put it in. Probably more trouble than its worth because I know I'm gonna get stupid questions now.
                If everything gets delivered like its supposed to it will be on all 4 wheels this weekend.
                  resized the rods..
                  WJ knuckel work
                  line everything up and mock it with an old hub
                  into the oven to prep the cast steel to weld
                  on to the bench, wrapped in a welding blacket to prevent it from cooling too fast
                  aaaaand now that fancy hot glue gun
                  done, this on all 3 sides of the spacer. he was bitching about the quality of that weld or something, idk seems good to me.
                    Hard to tell, looks like maybe not a lot of penetration on the knuckle? Either way, its just holding a spacer completely sandwiched in place
                      it looks good, he just has OCD about things. if he had the time he would have taken 6hrs to weld up both knuckles hahaha.
                        about to weld in the spring mounts, this look about right? jeep is off the stand and supported by the front suspension.
                          front axle fab work is done, but i forgot to pick up the other hub from the shop so this is as far as i got the other day.
                          my leaf perches and RE bushing came in the other day so now.... rear end work. finally have everything minus the one front arm to get it back on it's wheels. well maybe some brake lines but ehh you don't need those to go.
                            well almost killed myself getting to this point, it's heavy.
                            the pass side leave is some kind of bastard pack, is there an easy trick to lining up the leaf nubs?
                            ended up like this after a few trys
                            off the rear stands at last, the axle does need to be nudged over to the driver side about 3/4in though but i'm waiting till i have a 2nd person to help move this thing around.
                              also is it possible to change the title of this thread to "worst fucking idea i've ever had"?
