sye and new drive shafts?
    Originally posted by Henchman View Post
    Yeah but heres the thing. None of that says SiS Offroad on it. These are precious. Anyway before you put your lift in, make sure to check these things before install:
    Muffler Bearing
    Halogen Light Fluid
    Tire airators
    Make sure to also check you inner joint fluid. Top it off with ATF.
    Also if your axle bushings are bad buy some rejuvenation fluid for them.
    Oh and most important make sure your seals have the required amount of nuetella in them or the may burst.
    Jeeps don't get stuck ... they just take a nap when they are tired of being awesome
    93 2DR XJ 8" lift D30/D44 4.56's 35" MTRs IRO Y-link Build:http://sisoffroad.com/forums/showthread.php?t=9658
    Eric
      Muffler Bearing
      Halogen Light Fluid
      Tire airators
      Pretty much, he's saying to shop here http://kalecoauto.com/index.php?main_page=index&cPath=2
        This thread is full of tech
          can i just add some aluminum dust to my gas,and sprinkle some in my intake and skip the other steps? and zomg i think im going to love this store http://kalecoauto.com/index.php?main_page=index&cPath=2 its got every thing i need
          2000 xj 4.5 clayton longarms with wontons with a touch of
          97' zj
          2012 surbra imperza DD
          im a motivation machine like the hammer and sickle in communism
            http://kalecoauto.com/index.php?main...7h146qaen0ocd2
            Hey I think this may be the issue with my jeep mine are not hollow so the molecules can't flow freely oh and WHY DID NO ONE TELL ME ABOUT THIS http://kalecoauto.com/index.php?main...&products_id=7 !!!!!!!! Would have saved me a lot of time with my engine top end!
            Eric
              keep on killing it
                Originally posted by Magilla View Post
                keep on killing it
                Eric
                  It was funny the first time, MAYBE the second. Just MAYBE.
                    okays back to a real question is a transfer case drop as easy as putting spacers and longer bolts onto the skid plate and all the transmission shit? because all the wires look long enough
                    97' zj
                      basically yea it is not drastic you should only need 1" if that. everything will have enough play for that
                      Eric
                        hopefully i can do everything before oerII
                        97' zj
                          the drop is simple, but its only a bandaid, and ultimately not a good choice as you'll loose ground clearance. After my tcase/slip yoke explosion, i will never wheel a vehicle without one again. makes life alot easier when you start breakin shit.
                          ohhhh and for the lift don't play games. just do it...........
                          http://claytonoffroad.com/product_in...roducts_id=135
                            Umm its too late its all ready passed
                              its pretty much the drop and then realigning your transfer case linkage in some cases, just keep your fingeres crossed that the nuts in the frame hold tight and aren't just spinning....oh and don't forget the flux capacitor
                              1981 CJ8 - old & dumb
                              1988 Cherokee Limited - The Real Cherokee
                              2001 TJ Sport - DD
                                just noticed fucking funny catch
                                Eric
