n e ideas
  • n e ideas
    ok so i got a set of YJ flares for my trimmed XJ fenders any one got a good way to mount em? i only have like an inch of metal left between my door and the well so i think im gonna have to mount the flare to the door and cut it. but just wanted to see if n e one here had some ideas.
    aslong as its nice saturday i plan on tryin to mock em up.
    PS: thanks ERIC "trained monkey"
    #becauseJoeNitro
    Saturday
    I thought you were gonna just pop rivet em on
    If saturday weather sux you are welcome to use one of my garage bays. I will be highsiding the pass side on the why-j and trying to figure out how i want to comp cut it. plenty of tools on hand.
    If you can buy the parts in a store, is it realy custom?
    -T.M.
    Plans: dodge bullets.
      im ghetto and use self tapping screws
        Sam said zip ties, they will break before your fender or flare breaks.
          haha yea i have them mocked up wit self tappers now but the end of the screws sticking threw the fenders will cuz my tires so im gonna pop rivet em on but zip-ties would work too but im lookin for a more permanante fix...
          #becauseJoeNitro
            perminant fix=C4 go with good temp fix insted!
            Mud flaps come to mind...just while you are DDing it. see below from http://www.cga.ct.gov/2007/pub/Chap2...#Sec14-104.htm
            Sec. 14-104. Fenders and other wheel protectors. (a) No person shall operate on any public highway any motor vehicle with a passenger or commercial registration which is not equipped with fenders on all wheels which come into contact with the highway unless the body of the vehicle or attachments thereto afford adequate protection to effectively minimize the spray or splash of water or mud to the rear of the vehicle.
            (b) No person shall operate or cause to be operated any bus, truck, truck-tractor, full trailer or semitrailer of registered gross weight exceeding three tons on any public highway unless the same is equipped with suitable metal protectors or substantial flexible flaps behind the rearmost wheels, and, in case the rear wheels are not covered at the top and rear by fender, body or other parts of the vehicle, the rear wheels shall be covered at the top and rear by protective means of such standard type or design and so installed as to reduce, as far as practicable, such wheels from throwing dirt, water or other materials on the windshields of following vehicles, except in cases in which the motor vehicle is so designed and constructed that the above requirements are accomplished by reason of the fender or body construction or other means of enclosure.
            (c) Violation of any provision of this section shall be an infraction.
            (1953, 1955, S. 1340d; February, 1965, P.A. 448, S. 13; 1969, P.A. 576; P.A. 76-381, S. 6; P.A. 90-263, S. 65, 74; P.A. 99-268, S. 5; P.A. 00-169, S. 22.)
            History: 1965 act added "truck tractor" to first sentence of Subsec. (b) and deleted provision exempting vehicles requiring complete freedom around the wheel area from last sentence of Subsec. (b); 1969 act amended Subsec. (a) to require fenders on all wheels in contact with highway unless vehicle is equipped to minimize spray or splash of mud or water and specified applicability to passenger or commercial motor vehicles and motorcycles; P.A. 76-381 replaced provision re fine and/or imprisonment with statement that violation is an infraction; P.A. 90-263 amended Subsec. (a) to substitute phrase "motor vehicle with a passenger or commercial registration" for "passenger or commercial motor vehicle or motorcycle"; P.A. 99-268 amended Subsec. (b) to delete exemption for farm vehicles; P.A. 00-169 revised effective date of P.A. 99-268 but without affecting this section.
            See chapter 881b re infractions of the law.
            Please note: not from a snapple cap.
            -T.M.
              ok so i got the front and rear YJ flares mounted and took the truck to my mechanic so he could check it out and sign off on my ticket. he said the rear was good but the front dident quite cover enough and it should go furthur down. i went to lowes tonight and baught 4 sheets of dimond plate to make some blingin flat fenders pics tmr once im done so it happened....
              #becauseJoeNitro
                haha fucking WIN
                  that sounds terrible. good luck with that
                    OK OK OK OK....
                    FIXED
                    #becauseJoeNitro
                      Money back on flairs
                      Hey JoeNitro,
                      If the flairs I sold you are still useable on my wrangler just bring them back and i'll give your cash back. you got my #.
                      BTW: love the new flairs. !@#$ DMV
                      -T.M.
                        well i only have the front ones the backs i used so....
                        #becauseJoeNitro
                          #becauseJoeNitro
                            They look a lot better black and with the sides cut off Joe.
                              thankyou sir...
                              #becauseJoeNitro
