pitman arm
  • pitman arm
    i'm doing a 3.5 inch lift and ned a pitman arm, anyone got one?
    actually...been hearin a mixxed bit.
    I looked on some other forum and they said with a 3.5 its not necesary....can anyone give me a true write up of what parts i need. what parts i can hold off on. and what parts are a joke?
    thanks agian, this should prob be in newbie or tech. Moderators, feel free to work you magic if you choose.
      Definitely don't need it.
        x2 100% do not need one
          Nice little weight off my shoulders.
          So realisticly all I need is
          Shock,
          Coil
          Full leaf
          Does mountaining hardware (bolts bushings) usually come with a kit?
          And will i need to replace the u bolts?
          Once agian thanks all.
            Shock,
            Coil
            Full leaf
            control arms too. mountaining hardware is not included but mounting hardware might.
              I can't figure out if bushing come with the new leaf spring (full spring pack through rustyoffroad)
              And if the bolts aren't in too bad shape can they be reused to mount the new leafs/springs. They don't use salt in nf, so apart from a light color change, the bolts look okish
                they do, but they suck ballsack. id recommend swapping them out for MOOG ones, im 99% sure they use the same size as stock. you NEED new u bolts, you can get them at advance auto.
