No Dashlights or Tail/Running lights
  • No Dashlights or Tail/Running lights
    fuse blows every time i put one in, its been happening since the drive TO rausch creek.
    im just looking for opinions on were to start.
    if i check the fuse block i get 12 volts from the fuse that blows, so im guessing its grounded somewhere.
    tomorrow im going to unhook the headlight switch and check for short and then im going to pull the taillight and start cutting off sockets ( i have already checked those wires and sockets visually) but maybe there is something i cant see
    i guess i need to check the front running light sockets too
    my last resort is pulling interior and unwrapping the harness, but i want some more ideas before i go through that headache
    Kick it and push the hard reset
      I had a similar problem. I had to replace the headlight switch, 2 fuses, and double check all wiring..make sure it's not grounding out under back seat. Id like to say the head light switch made the difference
      Originally posted by Lawn Guyland
      Originally posted by Zullius Caesar
        Check the rear hatch glass switch. They tend to ground out and blow fuses, then ground out to the rest of the light circuits in the back. That thing was in a front end collision, right? check the harness where it's close to the left inner fender, where it goes through the firewall, and check the main breakers behind the passenger kick panel.
