Ok..... Wtf happened? Batt unhooked for a while, messed with radio, all fuses good, finally able to drive the damn thing and this.... Ideas?
Gauges no work, says "no bus"
I had same problem...replaced the entire harness that attaches to battery....problem solved....was super corrodedLast edited by hippie metal; 07-31-2014, 10:31 AM.Originally posted by HitItWithSomeSpeeddidnt this thread start with Jon being gay? what happened to that?Originally posted by Lawn Guylandhe's still gay we've just moved on to more important issuesOriginally posted by Zullius Caesari grab dude's junk all the time, doesn't make me gay.
Originally posted by sardo_67 View PostWhat more info is there?
The ECU isn't connecting to the gauge cluster, I've checked all the connections and fuses...... Any other ideas?OER The bad judgment Olympics.
Try popping out the gauge cluster (Really easy). Douche the contacts with electrical contact cleaner. Lube the connectors with di electric grease. Put it back in and see if it works.
I've had this problem on every 97+ XJ. fixes it every timeLast edited by justtorchit; 07-31-2014, 07:17 PM.Originally posted by Ktmracer419some people choose video games
Originally posted by justtorchit View PostTry popping out the gauge cluster (Really easy). Douche the contacts with electrical contact cleaner. Lube the connectors with di electric grease. Put it back in and see if it works.
I can get a new dash for a 6 pack from a guy, should I pick that up just incase?
Originally posted by sardo_67 View PostOh god dammit!!!!Originally posted by HitItWithSomeSpeeddidnt this thread start with Jon being gay? what happened to that?Originally posted by Lawn Guylandhe's still gay we've just moved on to more important issuesOriginally posted by Zullius Caesari grab dude's junk all the time, doesn't make me gay.
