95 XJ no dash lights
  • 95 XJ no dash lights
    Since I bought the XJ the illuminating background lights on the gauges never worked..as well as the heater panel.. no lights there either, nor does the blower work at all. Kid I bought the car from, says he checked all the fuses, but I'm not too sure about what he did or didn't do..the shift light and all other idiot lights work fine..just the illuminating lights.....not sure if it's related, but the green ring around the key tha lights up goes on and off.....
    Also, not a big deal, but since it's the BASE BASE BASE model xj....is there any reason my cluster with a tach won't just pop in?....as well as a wiper switch with a resistor in it? Tired of wiper settings being low, high, and off
    Originally posted by Lawn Guyland
    Originally posted by Zullius Caesar
    do you have tail lights? there probably on the same circuit, check voltage at the fuse block. 95's are common to short at the back of the gauge cluster.
      Have tails
