5.9 hard starting
  • 5.9 hard starting
    After sitting for more than an hour my zj starts very hard, it turns over fine, but struggles to fire at first( 20 seconds or so ) and then it misfires for a few seconds until it runs good.
    Im goi g to start with a fuel filter and go from there
    Anyone have a good starting place
    didnt realize i have to drop the tank to change the fuel filter, im guessing its a bad check valve in the regulator now, if i turn the key on and off 2 or 3 times it starts great, think this will cause a problem
    i really dont want to try and do it before oer.
      The 5.2 filter is external... I'd assume the 9er is the same. 4.0 is internal for sure but why make one V8 one way and one different...
      Sent from my pay phone in Chechnya
        ^^^^^b/c JEEP.
        Add on... I have a manual for grands I think the 5.9 is in it I'll look for info.
        1984 2.8 V6 XJ 2 door, 3'' lift 33'' general grabbers, 4.56 gears and half dead #rebuild
        2002 4.7 WJ stock with K&n intake-DD
          Thanks, ill mess with it after oer, but tommorow i need to figure out why the outside of one of my new front tires is chewing
            All V-8 ZJs are the same, it's up above the rear axle.
              It always chewed....thought maybe fresh tires would fix that. Ball joints okay?
                Alignment.
                  Originally posted by Robin Fairchild View Post
                  Partout.
                  Fixed.
