xj clockspring
  • xj clockspring
    What does it do?
    BC now my blinkers don't work and my airbag light is off I'm guessing its the clock spring b about two months ago I pulled a piece of copper out from behind my steering wheeling my air bag light has been on for ages I think I broke it when I put my power steering box in
    2000 xj 4.5 clayton longarms with wontons with a touch of
    97' zj
    2012 surbra imperza DD
    im a motivation machine like the hammer and sickle in communism
    Originally posted by hoggie101 View Post
    What does it do?
    Yup. Blinkers dont go through it, but the air bag does, as well as the horn.
      i messed with these alot matt, so if you need help let me know.
        pull yours out and go to the junkyard pull one out of your same era xj and compare the model numbers on the clocking spring. Another problem John and I had was the steering shafts are different diameters on some of them. Just make sure the steering wheel is strait forward when you take the one at the junkyard off and then install it in your jeep with the tires strait forward.
        04 WJ, 6.5 inch lift on 35'' MTR/K, Clayton long arms,locked
        Jon
          My wheel is upside down when I drive straight...
          97' zj
            It will cancel the blinkers though right?
            Matt I have a steering wheel puller if you want to borrow it.
              blinkers have nothing to do with the clock spring
                No, clock spring is only the contact between what is on the wheel that turns, and the column.
