leaf spring bolt, front side
  • leaf spring bolt, front side
    is there a trick to getting these loose ? my impact wont touch them, where they are located i really dont want to snap them off either. pb blastered them the best i could through the hole in the frame rail. any tips ?
    Redoing my entire suspension and besides the usual snapping of upper shock bolts in the rear the leaf springs is where im stuck at now
    Have you removed the rear bolts yet? I am envisioning you have the bolt out enough that the spring has shifted the bolt in the eye so it's on an angle now and virtually impossible to remove. If you take all the tension off the suspension it may make it easier. Or another option would be to make sure the bolt is completely out of the frame rail and cut it out, a new bolt is around $10 from the dealership.
      I usually put a long bar on them and sit down towards the rear and push the bar with my foot. My impact wouldnt take mine out either.
        do as Dan said. take your time...
        I also work it back and forth. everytime time i loosen it a 1/4 turn or so i tighten it back up and do that a couple times... this will help the bolt from getting stuck in the bushing once the threads are out of the frame.
          drill a small hole in the "cup" and get a torch tip on the nut.
          works amazing. If you don't have a torch, this also is an easy way to soak it with penetrating oil.
            sawzall....
              ill have to try the suggestions next time im at the shop. lucky i am able to do this on a lift , had the axle held up/tension off springs with some tall screw jacks. I knew you guys would have some ways. This is my first leaf spring suspension to work on, Wrangler's were much easier to remove the springs haha.
              I replaced all 4 shocks (all 4 upper shock bolts broke, had to air hammer out and replace with new bolts)., steering stabilizer, sway bar bushings + end links yesterday and tried the springs but ran into the bolt issue. my jeep is going to feel like a new cherokee once the springs are replaced, the stock springs are sagged probably like 5". between how sagged they were and the blown shock i had in the rear it was hitting the bump stops over small potholes....
