Manual hubs on a 30?
  • Manual hubs on a 30?
    Im looking into doing something with manual locking hubs. I have a hp 30 but don't want to spend the $800 on the warn hubs. I've read about cutting the c's off of a cj 44 and swapping them over to the 30 but i don't have nearly enough skills to do that.
    Has anyone ever looked into a project like this? im keeping my eyes out for a cheap 44 that i can build over time (like a winter project) but chances are ill be to cheap to invest in another front axle in the near future.
    only if you're willing to go 5 on 5.5 that's what all CJ have.
    are you currently 5 on 4.5?
    I have outers from a ford D44 you can have cheap they are 5 on 5.5, u-joint should be the same so you can just swap everything out
    Sounds like a lot of work for little gain if you ask me.
      I would be able to get adapters for the bolt pattern correct? and what is involved in putting the 44 outers?, i would like to spool the front (of course they don't make them for the 30) and just unlock the hubs for the street. I think that i might just save the money for a cable locker
        they make spools for the 30 you got a welder right?
        i would not spool it though
          funny that i was typing that then deleted it. I've heard bad things on welding a 30 carrier but if i can do something like that and unlock the hubs i would be set.
          I got on this idea looking at my buddies chevy with a welded front.
            buy an aussie or save your money leave it as is and build a 44 like you said
              you have a disco 30 right? why not just Aussie it and run a cable to the disconnect?
                non disco i believe, thats why i haven't locked it yet.
                  You geared it, right? When you did the 30, did the long shaft come out as two pieces?
                    like an inner and outer? both shafts are in two pieces.
                      Just inner of the u-joint. Not including the part outboard of the ujoint.
                        it was all one piece besides the u joint seperating the inner and outer.
                          On an 89? did you swap front axles?
                          I thought Renix era was all vac-disco. My bad if I'm wrong, though.
                            My axle is from a 90 xj with abs.
                              If you can find one with vac-disco, that could be useful in some cases. Probably don't feel like swapping the whole housing just for the mid-shaft disconnect, though. I wouldn't blame you.
                              Probably asked, but why manuals instead of a front Aussie? The locker's only engaged when there's power to the driveshaft, so in 2wd it's fine.
