School Me on building a 3 link
  • School Me on building a 3 link
    Going to be building a 3 link on my new rig and have been doing some homework on it trying to figure out everything. Basically looking for any insight you guys can give me, I figure the more knowledge I can get the better
    PLAY WITH THE CALCULATOR, TAKE ALOT OF MEASUREMENTS.
    SEE WHAT YA LIKE
    KEEP YOUR ANTISQUAT UNDER 100%.
    TRY TO KEEP THE LOWERS CLOSE TO HORIZONTAL.
    KEEP SOME GOOD VERTICLE SEPERATION ON THE AXLE.
    THE POSITION OF THE UPPER HAS ALOT TO DO WITH YOUR NUMBERS.
      SEE WHAT YA LIKE
      Ive been trying to figure out the calculator lol its a bit confusing
        I THIKN THERE IS A READ ME FILE OR SOMETHIN LIKE THAT THAT YA CAN USE... ITS DEF A BIT CONFUSING AT FIRST, BUT IF YA LOOK THRU OTHER PEOPLES PLANS AND GET SOME IDEAS WITH THEIR NUMBERS YOU CAN FIGURE IT OUT PRETTY FAST
          SEE WHAT YA LIKE
          I agree with the bold.
          Dont worry about the numbers. You can build an awesome 3 link in the calculator but if your COG and all the inputs arent right then the numbers are off anyways and 99% of the time it wont fit how you built it in the calculator anyways. Build it so it fits the rig. Keep the links as flat as possible and as much seperation as you can fit.
          Bent Fab Evo4 Rockwell Buggy
          2011 Silverado 6.2L LT
          2009 Pontiac G8 GT
          2004 Z1000
          1999 TJ
            my lowers are 2degrees at ride height, my upper is -3 degrees, there is 8inchs of vertical seperation. although depending on the rig (if its an xj), you probably won't be able to get away with a lower angle that flat and still have any uptravel at all.
            3 link is difficult with an xj though cause theres not alot of clearance for that long upper arm (depending on how much lift you are running), thats why i really like sam's mid arm setup for an xj not running a crap load of lift. Don't get me wrong it can deff be done effectively, but like toreadorranger said it will be hard translating from the calculator to the vehicle, your measurements need to be spot on and you're gonna have to spend alot of time going between the truck and the computer.
            post us pics as you go
              Thanks for the advice guys And as soon as I can get some cash together Ill get the ball rolling on this... I kinda think im just going to build it on the rig and use the basic ideas of a 3link and hope for the best... whats the worst that could happen I have to start again? This is definatly a learning experience for me
                Eureka!
                  DONE
                  #becauseJoeNitro
                      Originally posted by JoeNitro View Post
                      DONE
                      FAIL!
                      Longarms and coils>Leaf Springs in almost every way other then simplicity
                        cant say i totally agree but that doesent matter
                        why build a custom 3 link when you can buy a long arm kit like everyone else?
                        #becauseJoeNitro
                          Who wants to be like everone else?..... though this thought has crossed my mind to just but a longarm kit and be done
                            god damn it now youve got me thinking about buying a longarm again!
                              apparently everyone else wants to be like everyone else haha thats the problem....
                              im just kidding dude. make your own. do something different. only reason noone else does what we do is because they cant, or are afraid
                              #becauseJoeNitro
