Stock Cherokee specs
  • Stock Cherokee specs
    84 - Base, Wagoneer, Pioneer, Chief
    85 - Base, Wagoneer, Pioneer, Chief, Laredo
    86 - Base, Wagoneer, Pioneer, Chief, Laredo
    87 - Base, Wagoneer, Pioneer, Chief, Laredo, Limited
    88 - Base, Wagoneer, Pioneer, Chief, Laredo, Limited, Sport
    89 - Base, Wagoneer, Pioneer, Chief, Laredo, Limited, Sport
    90 - Base, Wagoneer, Pioneer, Chief, Laredo, Limited, Sport
    91 - Base, Briarwood, Chief, Laredo, Limited, Sport
    92 - Base, Briarwood, Chief, Laredo, Limited, Sport
    93 - Base, Sport, Country
    94 - SE, Sport, Country
    95 - SE, Sport, Country
    96 - SE, Sport, Country, Classic
    97 - SE, Sport, Country
    98 - SE, Sport, Classic, Limited
    99 - SE, Sport, Classic, Limited
    00 - SE, Sport, Classic, Limited, Freedom
    01 - Sport, Limited, 60th Anniversary Edition
    What Engines were offered?
    2.5L I4 carbureted - 105 hp @ 5000 rpm, 132 ft lb torque @ 2800 rpm - used in 84-85 models
    2.5L I4 TBI (fuel injected) - 117 hp @ 5000 rpm, 135 ft lb @ 3500 rpm - used in 86 and updated in 87-90 to 121hp
    2.5L I4 MPI (multi-port injection) - 130 hp @ 5250 rpm, 139 ft lb @ 3250 rpm - used in 91-00
    GM 2.8L V6 - 115 hp @ 4800 rpm, 145 ft lb @ 2400 rpm - used in 84-86
    Renault 2.1L 4cyl. Turbo Diesel - 85 hp @ 3750 rpm, 132 ft lb @ 2750 rpm - used in 85-87
    Italian VM 2.5L Turbo Diesel - 140 hp, 236 ft lb torque - used in overseas XJ's
    4.0L I6 EFI "Power Tech" - 177 hp @ 4750 rpm, 220 ft lb @ 4000 rpm - used 87-90
    4.0L I6 MPI "Power Tech HO" (High Output) - 190 hp @ 4750 rpm, 220 ft lb @ 4,000 rpm - used in 91-95 and updated in 96-01 to 225 ft lb torque @ 3000 rpm (00-01 models use a distributorless ignition system)
    What manual transmission were available?
    AX4 - 4 speed manual - manufactured by Aisin - used 84-86 with 2.5L I4 and 2.8L V6 engines
    T4 & T5 - 4 & 5 speed manual - manufactured by Borg Warner - used 84-86 with 2.5L I4 and 2.8L V6 engines
    BA10/5 - 5 speed manual - manufactured by Peugot - used only up to 89
    AX5 - 5 speed manual - manufactured by Aisin - used with 2.8L V6 and 87+ with 2.5L I4
    AX15 - 5 speed manual - manufactured by Aisin - used with 4.0L I6 engines
    NV3550 - 5 speed manual - manufactured by New Venture - used in 00-01 in SE models with 4.0L I6 engines
    What manual transmission is best?
    Early XJ models had the Peugeot BA10/5 transmission. In 1987 the AX-15 became available. In 19xx the AX-15 came with an external slave cylinder. The Peugeot has a 21 spline output shaft vs a 23 spline in the AX-15. The A15 ratios are (1st to 5th) 3.83 2.33 1.44, 1.0, and .790
    What automatic transmissions were available?
    Torqueflight 904 - 3 speed automatic - used 84-86 with 2.8L V6 and 2.5L I4 engines
    30RH - 3 speed automatic - used with 2.5L I4 engine 94?-00
    AW4 - 4 speed automatic, electronically controlled - manufactured by Aisin - used from 87-01 (87-91 models include a Power/Comfort button that adjusts the shift points)
    What transfer cases were available?
    The transfer cases used are all chain driven with aluminum housings. NP stands for "New Process" which is the brand, if you will. The newer ones are NV instead which stands for "New Venture". It is the same transfer case just a different name.
    NP207 - "Command-Trac" part-time only - 2.61:1 ratio low range - used 84-87
    NP231 - "Command-Trac" part-time only - 2.72:1 ratio low range - shift pattern 2H - 4H - N - 4L - used 87-01
    NP228/NP229 - "Selec-Trac" - 4Hi(full-time) - N - 4Lo (part-time) - used 84-87
    NP242 - "Selec-Trac" part-time OR full-time - 2.72:1 ratio low range - shift pattern 2wd - 4part-time - 4full-time - N - 4LO - used 87-01
    What are the dimensions of the XJ?
    Note: Small differences may occur depending on optional equipment or trim level
    wheelbase = 101.4"
    overall length = 165.3" - 168.8"
    overall width = 67.9" - 70.5"
    track = 58"
    height = 64"
    height with roof rack = 66.8"
    ground clearance (from differentials) = 7.3" - 8.3"
    approach angle = 37.6* - 38*
    departure angle = 31* - 32.1*
    breakover angle = 21* - 21.9*
    curb weight 2wd = 2,891 lbs - 2,993 lbs
    curb weight 4wd = 3,057 lbs - 3,386 lbs
    cargo capacity = 71.0 cu ft.
    What kind of driveshaft is used?
    Front Driveshaft - On 84-87 XJ's (NP207 t-case) the front shaft is a "GKN" style shaft. On 87-01 XJ's (NP231/242 t-case) the front is a "double cardan" two-piece driveshaft with a CV joint at the transfer case end.
    Rear Driveshaft - The rear is a one-piece shaft with standard u-joints at both ends. The slip yoke is located on the output shaft of the transfer case. On 84-95 models, the yoke slides in and out of the transfer case and is lubricated by the ATF fluid internally. On 96-01 due to a design change, the slip yoke is external (does not slide in and out of the transfer case). This slip yoke is covered with a rubber boot.
    What front axles were used?
    Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear - used 84-99 (some axles through 91 are vacuum disconnect, 92+ are non-disconnect, 89-95 with ABS have 5-297x u-joints, all 95+ have 5-297x u-joints, all others have 5-260x u-joints)
    Dana 30 low pinion - standard cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear, 5-297x u-joints - used 00-01
    What rear axles were used?
    (Note on Dana 35 axles sometimes referred to as Dana 35C - The "C" does not stand for c-clip. It stands for "custom" meaning it came from Dana unfinished.)
    (Note on 8.25 axles - none of these axles were used on XJ's with ABS brakes. If you have ABS, you have the Dana 35. Without ABS you could have either axle. 8.25 axles are c-clip)
    Dana 35 non c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used 84-89
    Dana 35 c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used 90-01
    Chrysler 8.25 - 27 spline, 1.17" diameter shafts, 8.25" ring gear, 3" axle tube - used 91-96
    Chrysler 8.25 - 29 spline, 1.21" diameter shafts, 8.25" ring gear, 3" axle tube - used 97-01
    Dana 44 non c-clip - 30 spline, 1.31" diameter shafts, 8.5" ring gear, 2.75" axle tube - used 87-89 on some(not all) XJ's equipped with towing package.
    What gearing was available?
    3.07 - used with 4.0L engine / manual transmission
    3.31 - only available on older (pre87?) 2 door XJ's with "Fuel Economy" package
    3.55 - used with 4.0L engine / automatic transmission
    3.73 - found in some XJ's with the towing package
    4.10 - used with 2.5L engine usually, and older XJ's with the "Off-Highway Vehicle" package.
    What cooling system was used?
    Open style - any normal cooling system used today. Opposite of closed style described below.
    Closed style - has no radiator cap and utilizes a pressure bottle. This style cooling system was used in 87-90 XJ's
    Were airbags used?
    Drivers side airbag (mechanical) was added in 95.
    Passenger side airbag was added in 97. Airbags changed from mechanical to electronic in this year also.
    How many XJ's were built?
    84 - 93,326
    85 - 120,328
    86 - 107,225
    87 - 139,295
    88 - 187,136
    89 - 207,216
    90 - 151,230
    91 - 151,578
    92 - 137,826
    93 - 144,961
    94 - 123,391
    95 - 120,234
    96 - 286,463
    97 - 258,958
    98 - 182,845
    99 - 186,116
    00 - 165,590
    01 - 120,454
    Introduction
    This page will detail the stock specs of the Jeep Cherokee (XJ) which was produced between 1984 - 2001 in the United States. That is a remarkable 18 year lifespan in which 2,884,172 Jeep Cherokees rolled off the assembly line! Originally designed and built by AMC, Chrysler continued the same design when they bought AMC in 1987. Anyways, the Cherokee was the icon of compact SUVs which led to a market full of those who tried to imitate it. Now the term "SUV" doesn't really mean a rugged vehicle that actually performs off the pavement, but the Cherokee remains one of the best "utility" 4x4s ever made.
    On to the specs. The information here should be of some help in identifying what parts came with what year Cherokee. I have made every effort to make sure this information is correct by comparing data from a variety of sources. If you notice any errors or have additional information to contribute, please contact me by PM or e-mail.
    The information on this page will be listed in the following order:
    Common Design
    Dimensions
    Body
    Engines
    Transmissions
    Transfer Cases
    Driveshafts
    Axles
    Gearing
    Cooling System
    Airbags
    Production Numbers
    Trim Levels
    Common Design
    All XJs were built as a "Unibody" design with the body and frame rails tied together as one piece as opposed to a body on frame design. All XJs have solid axles front and rear. The suspension consists of coils for the front and leaf springs for the rear. All XJs came with disc brakes in the front and drums in the rear.
    Dimensions
    (small differences may occur depending on optional equipment or trim level)
    wheelbase = 101.4"
    track = 58"
    height = 64"
    Body
    The body comes in both 2-door and 4-door styles with a rear hatch (liftgate).
    In 94 side-impact beams were added in the doors and roof was strengthened. The 3rd brakelight was added to the top of the liftgate.
    In 96 the body structure was strengthened some although it was not noticeable in appearance.
    In 97 the body (and interior) was redesigned to freshen it up a bit. Most noticeably it gave the body smoother lines by changing the bumpers, flares, and moldings. The front fender was trimmed just below the headlights and replaced with plastic bumper endcaps that wrap around to the wheel well. The liftgate was also changed from fiberglass to sheet metal in this year. The windshield washer bottle was also moved to the inside of the drivers side front fender.
    Engines
    2.5L I4 carburated - 105 hp @ 5000 rpm, 132 ft lb torque @ 2800 rpm - used in 84-85 models
    2.5L I4 TBI (fuel injected) - 117 hp @ 5000 rpm, 135 ftlb @ 3500 rpm - used in 86 and updated in 87-90 to 121hp
    Italian VM 2.5L Turbo Diesel - 140 hp, 236 ft lb torque - used in overseas XJs
    4.0L I6 "Power Tech" - 177 hp @ 4750 rpm, 220 ft lb @ 4000 rpm - used 87-90
    Transmissions
    Manual Transmissions
    T4 or a T5 may have been used instead of an AX4 or an AX5 due to supply shortages.
    Automatic Transmissions
    Torqueflight 904 - 3 speed automatic - used 84-86 with 2.8L V6 engine and ?
    Transfer Cases
    NP228/NP229 - "Selec-Trac" - 2Hi - 4Hi(full-time) - N - 4Lo (part-time) - used 84-87
    Driveshafts
    Front Driveshaft - From 84 thru 86 the front driveshaft was a true CV style ("beer can on a popsicle stick"), 87 + The front is a "double cardan" two-piece driveshaft with a CV joint at the transfer case end.
    Rear Driveshaft - The 228 and 229 transfer cases used a fixed output yoke, with a 2-piece driveshaft incorporating the slip spline. Otherwise, The rear is a one-piece shaft with standard u-joints at both ends. The slip yoke is located on the output shaft of the transfer case. On 84-95 models, the yoke slides in and out of the transfer case and is lubricated by the ATF fluid internally. On 96-01 due to a design change, the slip yoke is external (does not slide in and out of the transfer case). This slip yoke is covered with a rubber boot.
    Axles
    Front Axles
    Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear - used 84-99 (some axles through 91 are vacuum disconnect, 92+ are non-disconnect, 89-95 with ABS have 5-297x u-joints, all 95+ have 5-297x u-joints, all others have 5-260x u-joints except 84 thru 86 they were CV type rather than open u-joints)
    Rear Axles
    (Note on 8.25 axles - none of these axles were used on XJs with ABS brakes. If you have ABS, you have the Dana 35. Without ABS you could have either axle. 8.25 axles are c-clip)
    Dana 44 non c-clip - 30 spline, 1.31" diameter shafts, 8.5" ring gear, 2.75" axle tube - used 87-89 on XJs equipped with towing package.
    Gearing
    3.31 - only available on older (pre87?) 2 door XJs with "Fuel Economy" package
    3.55 - used with 4.0L engine with automatic transmission; also used with 2WD 4-cyl engines (possibly 4WD as well) equipped with the 4-speed manual transmission
    3.73 - found in some XJs with the towing package
    4.10 - used with 2.5L engine usually, and older XJs with the "Off-Highway Vehicle" package.
    Cooling Systems
    Closed style - has no radiator cap and utilizes a pressure bottle. This style cooling system was used in 87-90 XJs.
    Airbags
    Production Numbers
    # of XJs built in given year:
    84 - 93,326
    85 - 120,328
    86 - 107,225
    87 - 139,295
    88 - 187,136
    89 - 207,216
    90 - 151,230
    91 - 151,578
    92 - 137,826
    93 - 144,961
    94 - 123,391
    95 - 120,234
    96 - 286,463
    97 - 258,958
    98 - 182,845
    99 - 186,116
    00 - 165,590
    01 - 120,454
    Total = 2,884,172
    Trim Levels
    96 - SE, Sport, Classic, Country
    97 - SE, Sport, Classic, Country
    Here is a chart to help you figure what length your arms need to be at certain heights. Control arms lengths are important for castor and location of axle in the wheel wells. At 3", you will be ok with stock arms, just expect the axle to move back toward the cab a little and some minor bumpsteer.
    Control Arm Length Application Chart
    For Jeep Cherokee (XJ)
    Lift...........Lower Control Arms/Upper Control Arms
    ********Decimal**Fraction**Decimal**Fraction
    Stock........15.75.......15 ¾........15.00.......15
    2”.............15.92.......16............14.88.. .....15
    3”.............16.09.......16............14.92.. .....15
    4”.............16.33.......16 3/8......15.03.......15
    4.5”..........16.47.......16 ½........15.11.......15
    5”.............16.62.......16 5/8......15.21.......15 ¼
    6”.............16.97.......17............15.44.. .....15 ½
    7”.............17.36.......17 3/8......15.74.......15 ¾
    8”.............17.81.......17 ¾........16.09.......16
    9”.............18.30.......18 ¼........16.50.......16 ½
    10”...........18.82.......18 ¾........16.96.......17
