Doubler/D20 twinsticked setup
  • Doubler/D20 twinsticked setup
    D&D Machine billet aluminum 231 planetary doubler box - 2.72:1
    Early Bronco D20 with Jeep t-case pattern conversion - 2.46:1 (I think)
    D20 is twinsticked. Comes with broken Jeep speedo conversion thingy.
    Together this gives 6:36:1 when both cases are in low.
    I have had this setup for almost 3 years and haven't had any issues with it. Looking down the road, I need something stronger than a D20. Everyone here has seen this setup take a beating so it's not weak by any means, but doesn't offer much room for improvement.
    Would be an awesome setup for someone with a 5spd. If I remember correctly, a stock front driveshaft fit in the rear with my 8.8 pushed back 1". Front shaft will need to be lengthened.
    $1200
    Lemme know if you have any questions.
    97 XJ.
    97 XJ.
