SOA questions
  • SOA questions
    I plan on going SOA on the Comanche. My question is: I've heard that MJ springs are further apart than those on an XJ. Is this true? I have the old chryco axle out of my cherokee from swapping in Pete's axle, and wondered if it could bolt right up without having to grind off and attach new perches. If they are wider, by how much? Do I need to weld them with a preset angle to correct the pinion to compensate for going SOA instead of spring under?
    Go to bed
      Originally posted by ninetysix-ex-jay View Post
      Go to bed
      Isn't it past YOUR bedtime?
      Or does your height fool me?
        Wow... sick overplayed burn.
        Jon... I hate it when people get short with you. I got your back Jon.
        2013 F150 fx4 (Tow Pig/DD)
        • 5.0 with the 3.73 option
        2003 TJ Rubicon
        • 4.0/42rle/np241or
        • 5.13's
        • 33” BFG KO2s
          Or just stay spring under and buy this...
          http://naxja.org/forum/showthread.php?t=1028281
          2003 TJ Rubicon
          • 4.0/42rle/np241or
          • 5.13's
          • 33” BFG KO2s
            ^^ sold. But it would of ben sweet. Rob, you will need to change your spring mounts, shock mounts, etc... You will need to find the correct pinion angle too.
            Look here.
            http://www.ruffstuffspecialties.com/catalog/index.php
              If the widths are the same, and I would think they are, just throw an 8.25 under it, which is already setup up for SOA, then as long as the pinion angle is fine you should be all set.
                They arent the same, MJ springs are further part than XJ springs I think.
                  just get some new antiwrap perches. cuttin perches off and weldin new ones are aint no big thang.
                  and yes, figure out your pinion angle while you are doing this
                    you sure its not a dana 35?
                      Dont you have an MJ and an XJ?
                      This shouldnt be a hard question to answer yourself
                      2 Broncos are better than 1
                        Touché, salesman
                          Both the Comanche, and the axle are in your driveway aren't they? Go outside and use a tape measure.
                            nope. axle's over at Caleb's.
