box with big wheels thing i'm making
  • Gear oil is in and everything is sealed up. Ready to go in
    Primer here but it got flat black soon after, floor is done. Just need to make 2 holes for the doubler cable and trans.
    In for good this time.
    • More poor life choices, ordered one of these.........
      Friend from work is in the process of installing one in his 6.0 TJ.
      • Was way easier than I expected, not even 2 hours to get to his point.
        • Comment
          • wheres this thing gonna have the first shakedown run? other than the mall
            • Originally posted by HeavyMetal View Post
              no idea, hoping it will be on a trailer headed north to get the brake lines made and wiring finished. after that it should at least start and run.
              Here's the hard part where i stopped last night
              • It moved, little bit closer
                • Dropped off in mass for the last bit of work
                  • Brake lines are all set, when it's not raining we'all install and bleeds them. Looking like Monday evening the wiring can get all tied up and maybe even start this turd.
                    • So god damn close!!
                      Brake lines are hooked up, still need to be routed and attached then
                      The hood is back on it as well, finally don't need to cover it with a tarp.
                      • How much of a pain is it making the Racepak work?
                        • Originally posted by Robin Fairchild View Post
                          Probably not that hard. I paid a guy to do mine.
                          • Brake and fuel lines run, fuel system completed and all finalized, heat sleeve on the sections that need it.
                            Battery issues so it's kinda half assed on the ground with jumper cables.
                            Cranked and shot wires, tested things, checked more wires, cranked and cranked. No start, I didin't have the correct O2 sensors so we are guessing the ECU didn't see the sensors so it wouldn't start. Josh at 208 did the wiring and ECU tune so I'm not 100% sure how he programmed it.
                            • Took a while. It runs now.
                              • Still needs a lot of work. But it starts and moves.
                                https://youtu.be/GSKViEtPzuc
